Optoma GT700 + AMD Radeon HD 6570: Viewing 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-05-2011, 11:19 PM - Thread Starter
kwanbis's Avatar
I have an Optoma GT700, and I have ordered some parts for a HTPC.
The graphics card would be an AMD Radeon HD 6570.
The optoma is DLP-Link 3D Ready, and so is the 6570.
So, I should be able to connect both and watch 3D by using DLP-Link 3D glasses.
Now, the AMD page mentions DVI-Out, and NOT HDMI, is that correct? I thought I would be able to connect them through HDMI cable!
kwanbis is offline
post #2 of 2 Old 09-07-2011, 05:00 AM
BioSehnsucht's Avatar
Depends on the particular board layout of the video card you ordered, but nearly all 5xxx and 6xxx will have an HDMI port. Usually a combination of at least one DVI, at least one DisplayPort, and an HDMI. If there is no HDMI, it should usually come with a DVI to HDMI adapter, it's a little dongle that connects to the DVI port on the card and then the HDMI cable plugs into that.
What specific brand and model of 6570 did you order?
BioSehnsucht is offline
Reply 3D Tech Talk
