Anyone tried this 2D-3D (720p/1080p) converter from China ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 86 Old 09-09-2011, 03:28 PM - Thread Starter
evnow's Avatar
This looks similar the one Monoprice is selling - except it supports 1080p output.
http://www.dealextreme.com/p/1080p-h...onverter-92210
update : It is $78 here - http://www.aliexpress.com/product-fm...olesalers.html
one more vendor for just $64 - http://www.mart-shopping.com/2d-to-3...ox-ry-v3d.html
The details are sketchy - as they always are at deal extreme. But it looks like the unit puts out needed 1080p (probably SBS) output.
- HDMI V1.3/1.4 input (resolution 480P/576P/720P/1080I/1080P)
- HDMI V1.3 output (1080P/720P), 60Hz
- Supports max resolution: 1920 x 1080, full HD 1080P
- When playing on 2D TV, you shall use the included 3D glasses
- When playing on 3D TV, you shall use the shutter 3D glasses or polarized 3D glasses
Update : More info here 3D converter transfer 2D to 3D
Turn Your 2D Movies Collection to 3D in Real Time
Convert Real Time TV Programs to 3D
Real 3DMovies display at 2D HDTV in 3D effect
Work with 2D HDTV, 3D HDTV, 3D DLP Projector
Features:
2D to 3D real-time conversion
Support 2D HDTV, 3D HDTV, and 3D DLP Projector
Support 3D Ready DLP Projector
3D format Outputs: Red/Cyan (Amber/Cyan), Side-By-Side (Half), Frame Sequential, 2D and 3D bypass
Input: HDMI v1.3/v1.4, Output: HDMI v1.3, HDCP compliant
Plug-and-Play Installation
IR remote control
3D effect level adjustment
Contents of Package:
RY-V3D main unit *1
Red/Cyan or Amber/Cyan glasses *2
DC 5V/1A power adaptor *1 (EU standard/ US standard/UK standard/ SA standard/China standard, etc.)
User’s Manual *1
IR Remote controller (option) *1
Also,
Mode 2: 2D Program to 3D HDTV
When you want to convert 2D program into 3D effect and watch via 3DTV
Use Shutter (or Polarized) glasses designed for 3D HDTV
Level of 3D effect can be adjusted.
3D format output: 3D Side-by-Side (Half)
NOTE: (1) Users need to wear an active Shutter (or a passive Polarized) glasses to watch 3D effect videos on 3D HDTV.
(2) If the 3D HDTV requires an active shutter glasses for 3D viewing, please make sure the active shutter glasses can match with the 3D TV.
(3) If the 3D HDTV is a passive polarized 3D TV, please make sure the passive polarized glasses can match with the 3D TV.
(4) After converting, if you see two images (side-by-side) on TV, you will need to use TV remote/control to select input 3D format (please refer to TV's manual), to make two images into one 3D image.
Enjoying Nissan Leaf as the primary car for over 6 months : MyNissanLeaf.com
evnow is offline
post #2 of 86 Old 09-12-2011, 07:41 AM
8000HD's Avatar
Aren't the Monoprice one 1080p output too? http://www.monoprice.com/products/pr...#specification
8000HD is offline
post #3 of 86 Old 09-12-2011, 10:23 AM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
Sorry, but no. The 1080p is an input resolution. The Monoprice box outputs only 720p. There is a 5-page (and counting) thread on the Monoprice box here:
http://www.avsforum.com/avs-vb/showthread.php?t=1339157
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #4 of 86 Old 09-20-2011, 12:33 AM
freddyi's Avatar
looks like its worth a chance - wonder if it really toggles to blue-amber anaglyph?
freddyi is offline
post #5 of 86 Old 09-20-2011, 09:45 AM
mkoss's Avatar
It's the same price as the monoprice. Since the monoprice handles side by side half resulting in true 3D I think its a much better value. There's no indication from their spec other than 2d to 3d conversion that I would spring for them over the monoprice.
mkoss is offline
post #6 of 86 Old 09-20-2011, 10:04 PM
freddyi's Avatar
D3H blurb mentions SBS http://evik.en.alibaba.com/product/4...Converter.html
if it truly supports blue-amber then might be fun - if not too fatiguing to watch
freddyi is offline
post #7 of 86 Old 09-22-2011, 08:18 AM
nunofcp's Avatar
Quoted: 14 Post(s)
nunofcp is offline
post #8 of 86 Old 09-22-2011, 11:37 AM
freddyi's Avatar
think i'll bite - my main problem is E3D420VX isn't getting the proper aspect ratio - especially with widescreen movies (the vertical axis is squished somewhat) and that's so distractive that can't concentrate on converter quality. (3D Bee came yesterday - effects seem "mellow" - generally looks better in Z- mode)
"why are the 3D eyeglasses brown blue? Answer: This is relatively red because of the brown says is quite temperate, the human eye easy to adapt, the long time wears, the weary feeling does not have the safflower eyeglasses to be so intense" - does that mean its ~colorcode - or that the wearer will eventually adopt to the wrong filter? - LOL
freddyi is offline
post #9 of 86 Old 09-22-2011, 02:18 PM
mkoss's Avatar
This may be inferior to the monoprice in that it only supports 3D for anaglyph and not DLP as well for side by side input.
mkoss is offline
post #10 of 86 Old 09-22-2011, 02:30 PM
freddyi's Avatar
assuming it comes, will find out if it does anything well - would be happy if it really outputs colorcode anaglyph for my cheap 2D projector. -- still perplexed with getting widescreen movies to look right on E3D420VX so can't give the 3D Bee a good evaluation yet. Build-wise the Bee is in a light plastic case, there's two depth modes Z- and Z+, so far Z- looks best for the Bee. The 3D effect from the Bee is less "catchy" (and perhaps obvious) than on the Monoprice. If I ever sort the aspect problem out on E3D420VX then will be able to judge things a lot better than the torture of looking at squished images.
at least D3H's cardboard box looks similar to the Monoprice box :^)
freddyi is offline
post #11 of 86 Old 09-23-2011, 09:29 AM - Thread Starter
evnow's Avatar
Pls let us know if it does SBS as well. Thx.
evnow is offline
post #12 of 86 Old 09-23-2011, 10:29 AM
nunofcp's Avatar
Quoted: 14 Post(s)
Can we watch 3D bluray movies and 3D games with the PS3, using blue/ambar glasses?
nunofcp is offline
post #13 of 86 Old 09-23-2011, 12:55 PM
mkoss's Avatar
Only 2D bluray not 3D
mkoss is offline
post #14 of 86 Old 09-23-2011, 03:32 PM
nunofcp's Avatar
Quoted: 14 Post(s)
Games in 3D either?
nunofcp is offline
post #15 of 86 Old 09-23-2011, 04:26 PM
freddyi's Avatar
I've got my Monoprice fed by a cheap Pioneer DV-220V-K set for 1920x1080 and it looks very good for little money. Blue-amber anaglyph can look better on skin tones than red-cyan.
freddyi is offline
post #16 of 86 Old 09-23-2011, 05:53 PM
nunofcp's Avatar
Quoted: 14 Post(s)
You are sugesting that This device maybe have a better picture than the monoprice, or the monoprice is capable to use blue/ambar glasses too?
Im sorri im new on This.
nunofcp is offline
post #17 of 86 Old 09-23-2011, 07:37 PM
freddyi's Avatar
The Monoprice unit IIRC (am using it currently with a 3D tv) outputs anaglyph only for red-blue glasses. True "Colorcode" (patented spectrum filters) blue-amber glasses are only cheap in cardboard variety as supplied for Superbowl broadcasts and won't know how well D3H looks til it arrives and is checked both with 2D pc monitor and 3D tv. Before I gave a 2D 42" plasma tv to a friend, I was too dumb to set a dvd player's resolution correctly to judge the Monoprice unit with red-cyan glasses - ask others on how they like its colors in that mode. I'm impressed with the Monoprice 3D Creator running into a 3DTV with polarized glasses.
freddyi is offline
post #18 of 86 Old 09-24-2011, 12:38 PM
cyberized's Avatar
Quoted: 32 Post(s)
PLEASE tel us if the "new" one will do "Checkerboard" format too!
THANKS
cyberized is offline
post #19 of 86 Old 09-24-2011, 05:00 PM - Thread Starter
evnow's Avatar
If you have a 3D TV why would you bother with anaglyph ?
evnow is offline
post #20 of 86 Old 09-24-2011, 07:56 PM
freddyi's Avatar
anaglyph would only be for a cheap 2D projector that's not currently in use (and possibly my 2D pc monitor - if its compatible) - I love the Monoprice unit with polarized glasses
freddyi is offline
post #21 of 86 Old 09-25-2011, 01:45 PM
nunofcp's Avatar
Quoted: 14 Post(s)
Is very similar to monoprice, but it works with with both RED/CYAN and AMBER/BLUE.
nunofcp is offline
post #22 of 86 Old 09-25-2011, 03:23 PM
freddyi's Avatar
that's a much better price then what they ask at Ebay auctions.. Vefxi's 3D-Bee is very smooth with my E3D420VX and polarized glasses but rather expensive - 3D Bee produces a more rounded/homogenized picture vs the Monoprice giving a more discrete planes look.
freddyi is offline
post #23 of 86 Old 09-26-2011, 01:37 PM
freddyi's Avatar
I run the Monoprice from a cheap upscaling dvd player set for 1920x1080 out - IIRC (?) my E3D420VX says its getting 1080p
freddyi is offline
post #24 of 86 Old 09-28-2011, 07:54 AM
nunofcp's Avatar
Quoted: 14 Post(s)
I dont have a 3D dlp vp, or a 3D tv than i dont care about dlp glasses. I will use anaglyph system.
What mode do you think give me a better picture quality in a 2D HDTV with the anaglyph glasses to watch movies?
1º A downloaded 3D anaglyph mkv file using a media player directly to the TV.
2º A side by side half file converted to anaglyph with This device or the monoprice.
3º A 2D file converted to 3D anaglyph with these converters.
4º Or the picture quality with anaglyph glasses is similar in the 3 options.
Thank you
nunofcp is offline
post #25 of 86 Old 09-28-2011, 05:07 PM - Thread Starter
evnow's Avatar
think i'll bite
When are you expecting it to come ?
evnow is offline
post #26 of 86 Old 09-28-2011, 07:25 PM
freddyi's Avatar
its supposed to be on its way - maybe a week? - re: "checkerboard" - is that the same as Sensio?
freddyi is offline
post #27 of 86 Old 09-28-2011, 07:39 PM - Thread Starter
evnow's Avatar
If the source is already 3D - this should give you the best picture. Otherwise - who knows ? You would have to experiment and see.
evnow is offline
post #28 of 86 Old 09-28-2011, 07:40 PM - Thread Starter
evnow's Avatar
Checkerboard is what DLP RPTVs use for 3D format.
evnow is offline
post #29 of 86 Old 09-29-2011, 12:27 AM
nunofcp's Avatar
Quoted: 14 Post(s)
Thank you
nunofcp is offline
post #30 of 86 Old 09-29-2011, 09:05 AM
nunofcp's Avatar
Quoted: 14 Post(s)
http://www.alibaba.com/product-gs/45..._3D_Video.html
This one accepts Top & Bottom and frame packing.
Anybody knows if this means that this box can handle ps3 games and blu-rays?
nunofcp is offline
Reply 3D Tech Talk
