Anyone tried these new 3DTVCorp DLP Link Rechargeable glasses ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 09-28-2011, 09:39 AM - Thread Starter
evnow's Avatar
3DTVCorp has new style DLP Link glasses that are rechargeable. Has anyone tried them - and if so could you compare to the old non-rechargeable ones that look like Ultra Clear glasses ? They are about the same price.
new :
ebay item : 160560023321
ebay item : 150638277882
old :
ebay item : 150664959484
These new ones have the receptor at the middle, unlike the old ones that have it on a side. These also have a "Unique Polarity Reversal Button" that would be very useful.
One big problem is - they are white ! I've sent a message asking whether we can get the black ones. Currently the black ones are only available in large batches.
Enjoying Nissan Leaf as the primary car for over 6 months : MyNissanLeaf.com
evnow is offline
post #2 of 24 Old 09-29-2011, 01:33 PM - Thread Starter
evnow's Avatar
Well, I just bought the new rechargeable ones. I'll post a review once I get them.
evnow is offline
post #3 of 24 Old 09-29-2011, 02:12 PM
nickels55's Avatar
Liked: 36
What type of TV set or projector do you have (make/model)?
I know personally I am interested in seeing if these show on screen polarization rainbows like all other DLP lens I've used and if it blocks the DLP Link tint (are blacks actually black or tinted red).
Weight and comfort are also a concern, as is the amount of glare on the lens (can you see everything going on behind you).
Otherwise I'll stick with the Ultra Clear ones. I look forward to your review!
nickels55 is offline
post #4 of 24 Old 09-29-2011, 02:30 PM - Thread Starter
evnow's Avatar
Optoma HD3300 PJ.
evnow is offline
post #5 of 24 Old 09-29-2011, 07:16 PM
8000HD's Avatar
I have to pair of the white ones. One was free with my Optoma HD33 and the other cost me 60$CAD. I tough that they were Future Cinema Corp glasses. I would like to give you my tough but I cant compare with anything else.
8000HD is offline
post #6 of 24 Old 09-29-2011, 07:44 PM - Thread Starter
evnow's Avatar
Well, all these glasses are made in China by some OEM and gets sold under various brands/names by various US vendors.
Even if you can't compare - how well do these glasses work, as such ? How big are they ?
evnow is offline
post #7 of 24 Old 09-30-2011, 07:15 AM
waltermixxx's Avatar
I purchased a pair of these from Consignia, ( Jay just got them In and has not updated the web site to indicate them) and they work great with my HD33 projector. No ghosting, nice clear picture, and only $64.99 will most likely get a few more pairs... they came with the charge cable, and little cloth case, and cleaning cloth... fit over my glasses no problem.
PSN:Waltermixxx
Live:Whitby Wildcat
Shsssshshhhhhhhhh the movie's started....and it's in 3D...
waltermixxx is offline
post #8 of 24 Old 09-30-2011, 07:44 AM - Thread Starter
evnow's Avatar
Thanks. How big are the temples - can't make out from the picture. Are they wide like the old glasses ?
I'm still trying to figure out whether to get the old wider non-rechargeable glasses or the new ones - I've asked them to put my order on hold, till I can figure this out.
evnow is offline
post #9 of 24 Old 09-30-2011, 09:12 AM
rjyap's Avatar
Quoted: 45 Post(s)
Liked: 30
Can you put the glasses on a piece of white A4 paper and check if the glasses had a green tint?
rjyap is offline
post #10 of 24 Old 09-30-2011, 03:05 PM
8000HD's Avatar
Here is the web site of Futurecinema they are like the one's I own.
http://www.future3dcinema.com/
For the green tint, yes they have some. I dont know if the pic is good enough to give you an idea. They are about 6.5" exterior wide.
I just watched Green Hornet with my HD33 and theses glasses. One pair work flawless and the other one start flickering red/black/green after a while. Do you think it could be a power issue? Since they dont come with a manual/booklet I can't read anything about troubleshooting. I'll try to charge them all night long to see if they still do the same tomorrow.
8000HD is offline
post #11 of 24 Old 09-30-2011, 03:32 PM - Thread Starter
evnow's Avatar
Thx. From your picture - the lense looks 50x30 mm.
evnow is offline
post #12 of 24 Old 09-30-2011, 03:40 PM
8000HD's Avatar
They are more 55x40
8000HD is offline
post #13 of 24 Old 10-02-2011, 05:47 PM
rjyap's Avatar
Quoted: 45 Post(s)
Liked: 30
From the photo, the glasses look like it had the same green tint as UC. Not a big deal if you have the equipment to tune in the greyscale to compensate for the green tint.
rjyap is offline
post #14 of 24 Old 10-02-2011, 06:18 PM
shayking's Avatar
Don't forget the tint is green by design. The opposite color of the Green hue is Pink/ Redish.
Alot of display's/dlp's etc. have a pink tint while in 3d mode. To counter this pink/redish hue we need greenish and or grey tinted glasses.
As time goes on it's seems us consumers seem to prefer the Grey tint over the green. Is this because the tv's are none pink 3d mode tv's ? I don't know...
my 2009 plasma has the pink hue, and if i remove too much of the pink/redish hues, my glasses will show to much green hue. i plan to get some non green tint specs to do some tests.
I wish i had some crystal eyes, bit cauldron and a few pairs of different generics, to test all this stuff out, TV tint vs tint color quality etc.
shayking is offline
post #15 of 24 Old 10-05-2011, 08:12 AM
rjyap's Avatar
Quoted: 45 Post(s)
Liked: 30
I had a DLP projector and no pink/redish hues. I think some DLP TV and Optoma HD33 projector is using red flash. But my understanding red flash or white flash should be block by DLP link glasses as it use the flash as sync.
I feel that from PQ point of view, Optoma ZD201 is a better 3D glasses compare to UC DLP. I need to smooth the edge of the arm using sand paper and now it is as comfortable as UC DLP glasses.
rjyap is offline
post #16 of 24 Old 10-09-2011, 07:52 PM
dbshelton's Avatar
I bought a pair of these glasses. They seem to work fine with my Mitsu DLP TV but they won't stay on with my Optoma HD 3300 DLP projector. Any ideas why? The Ultraclear DLP glasses I have work fine with both. With the projector, they flash a couple of times when I turn them on, then go dead.
dbshelton is offline
post #17 of 24 Old 10-09-2011, 08:29 PM
gursimran1's Avatar
form the picture the glass look like same green tint.....
gursimran1 is offline
post #18 of 24 Old 10-11-2011, 04:12 AM
dbshelton's Avatar
Is the green light supposed to stay on when the button is pushed?
post #19 of 24 Old 10-13-2011, 08:05 PM
brianbonedoc's Avatar
I just bought 5 pairs for my HD3300. One pair works flawlessly, beautiful picture. One pair flickers practically causing a seizure, and 3 pairs don't even seem to turn on. Gonna return 'em. BTW got them from 3DTV store on ebay.
brianbonedoc is offline
post #20 of 24 Old 10-14-2011, 07:27 AM
nickels55's Avatar
Liked: 36
3DTV store has excellent service. When I had a problem the owner was very quick to help me out, and replied to all my emails very quickly. Sucks that they all didn't work flawlessly.
post #21 of 24 Old 10-14-2011, 01:27 PM
WACO's Avatar
Haven't tried those, but almost every other brand, and here are the new ones I finally settled on. They have everything you're looking for. They're rechargeable, foldable, rubber arms and nose pieces, receiver in the middle, awesome visual quality. They're just perfect, you can't go wrong with these new True Depth 3D glasses.
http://www.amazon.com/True-Depth-3D-...8623115&sr=8-1
WACO is offline
post #22 of 24 Old 10-14-2011, 03:43 PM - Thread Starter
evnow's Avatar
I got 2 pairs - they work well with blu-ray played through my HTPC and for DirecTV. But SBS played thr' the HTPC gives a lot of flickering.
I'm going to return these and try different glasses.
evnow is offline
post #23 of 24 Old 10-15-2011, 11:31 AM
8000HD's Avatar
One of my pairs have the flickering issue the other is working fine. Look like the price is cheap and the product too.
8000HD is offline
post #24 of 24 Old 10-27-2011, 08:07 PM
bluemetal77's Avatar
I did buy these unbranded direct from a chinese seller .. and they are back with him for a refund ..
Utterly useless to have a rich 3D experience, my observations were:
- too green tinted, all the white scenes were greenish!
- not enough contrast, all blacks were greyish in appearance
- transmittance, too high, in 3D mode the projector is already in bright mode, these glasses were letting too much light through making it too bright. If i turn the brightness down, the original 3D glasses would become too dark. It still didn't fix the problem that everything black was appearing grey.
- Occasional unsync, but that is really angle/movement dependent
Anyways, i prefer the grey tint as my projected image is not pinkish .. so i don't need everything to be green!
bluemetal77 is offline
Reply 3D Tech Talk
