Cheaper alternative to Optoma 3DXL for HD66 and other DLP projectors - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 152 Old 01-09-2012, 02:56 PM
paperchaser's Avatar
I wont be able to test things out till Weds morning.
interested in seeing what type of sources I can feed into the 3dxL for 3D and 2D - 3D
pretty sad that this is just an Optoma issue as well...maybe they did see this coming
paperchaser is offline
post #92 of 152 Old 01-09-2012, 05:04 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Originally Posted by canuck View Post
Exactly, CHOICE is key. I have no need for the more expensive 3d-XL because I really have no intention of buying a 3D blueray player. Which is clearly the intended usage in this setup. I really can't see me watching much 3D material at all.
What I want is something that will breathe new life into a handfull of animated 2D titles that my kids watch via DVD or the odd HD mkv file that I play directly from my wdtv. For this purpose, the monoprice unit is clearly the better option because of feature set ( 2d to 3d conversion, conversion of various 3D formats to one playable on the hd66) and price (wife factor, cheapo index) .
I felt the same about 2D to 3D but didn't care for the drop in resolution with the sbs option. I suppose if I had dlp Link glasses I would have had better results using 1080 input in sbs but my VIP theatre will only accept 720p images in sbs and that was too low a resolution after combining into frame sequential on a 120 inch diagonal screen. Once you see framepack on bluray its hard to look at 720p sbs. I love the monstervision RF glasses and just didn't want to buy dlp link glasses.
Ronomy is offline
post #93 of 152 Old 01-09-2012, 08:54 PM
perfectdark's Avatar
Don't listen to all these people
I have the 3D-XL and HD66 and I'm using the WDTV Live with Half SBS MKV's 720p and they look great on my 110" screen
perfectdark is offline
post #94 of 152 Old 01-09-2012, 08:55 PM
Originally Posted by lewis3845 View Post
This does not work because I cannot select 3d at all in the menu I think my hd66 must get the 120hz signal first so they crippled these projectors with the latest firware only to work with their box because that's what optoma tech told me 120hz first then 3d menu is selectable.
And yes the HD66 needs a 120hz input before you can turn on the 3D option
post #95 of 152 Old 01-09-2012, 09:54 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
[quote=perfectdark;21467886]Don't listen to all these people
I have the 3D-XL and HD66 and I'm using the WDTV Live with Half SBS MKV's 720p and they look great on my 110" screen[/QUOTE/]
I was referring to the monoprice conversion of 2D to 3D sbs output. There is some stair stepping in resolution...too many artifacts for my liking but I am picky. 720p on Directv sbs looks fine via my VIP theatre. Still not as sharp as bluray frame packed. The monoprice converter may look better with a direct connection to the projector. I just didn't have dlp link glasses to try it and I didn't need it to convert sbs to 3D. The theatre unit does that.
Ronomy is offline
post #96 of 152 Old 01-09-2012, 11:35 PM
[quote=Ronomy;21468160]
my apologies... i thought you were referring to the 3D-XL .... I didn't know you were speaking of this Monoprice adapter
post #97 of 152 Old 01-10-2012, 02:11 AM
whythis's Avatar
You just hook up your wdtv live to your 3d-xl and the 3d settings will come up on the hd66? I want to play sbs mkv tried switching the output the mp4 to play on the ps3 by flash drive the sbs 3d will not work because it is not 120hz. So if I put the movie on the wd tv live it will sense 120hz? I have the viewsonic converter box (vp3d1) basically the same I was just wondering thanks.
whythis is offline
post #98 of 152 Old 01-10-2012, 12:33 PM
Rodney538's Avatar
Hopefully this will help everyone out:
I received my Optoma HD-66 yesterday (it is used so I don't know exactly how old it is). I attached to to my cheap Dell laptop using the VGA port. Initially the laptop was setup to display 1280 x 800. My HD-66 would not allow me to activate the 3D since it was greyed out. I went into the display settings on the laptop and noticed that it was 60hz. There wasn't an option for 120hz. I then changed the laptop resolution to 1280 x 720. At this resolution it allowed me to changed the frequency to 120hz. I then went into my projector settings and sure enough the 3D menu was now active. I noticed that 2 other laptop resolutions allowed me to select 120hz. They are 1024 x 768 and 800 x 600. I couldn't actually test the 3D though since I don't have the 3d creator box. I am guessing that the 3D wouldn't work though since based on all of the research that I have been doing, that box only outputs 60hz to the projector. There is a similiar box to the 3D creator here on ebay: http://www.ebay.com/itm/3D-Converter...item3cc0b26b99
It shows that it outputs 60hz in the specs and in the FAQ's (question 8), it says that it does not support 120hz projectors. Also, 3dtvcorp sells the same box: http://www.ebay.com/itm/150707399639...84.m1438.l2649 (make sure you read the excellent description). I have the complete specs of this box in an email attachment and it shows 60hz output. I am not sure how the OP got it to work along with a few others (maybe they had older HD-66 firmware)
Then I tried this: I hooked up my 10 year old DVD player to the projector. I played an older 3D DVD called 'Encounters in the 3rd Dimension' DVD (not Bluray). The output of the DVD player was initially set to 16:9 Progressive. The 3D menu on the HD-66 was greyed out. I changed the output of the DVD player to Interlaced and then the 3D menu on the HD-66 became active. I selected DLP-Link and watched the movie in 3D with my DLP link glasses. At first I was shocked that the Projector could play 60Hz Interlaced but then I remembered that this projector supports, '60Hz Field Sequential 3D for Resolutions Up to 480i'.
I was thinking about buying the 3D creator box but based on my testing and knowledge, I don't think that it will work with this projector. My choices are to either buy a new projector (HD-65?) or the 3D-XL. I decided to buy the 3DXL since I will be able to play 3D Blurays besides SBS and it supports Over/Under which Time Warner Cable displays its 3D in.
I am thinking about buying a 3D Panasonic BDT110 Bluray Player or a WD TV Live. I have read that they can play 720p HALF SBS Mkv files but may have problems playing 720p FULL and possibly 1080p FULL/HALF. I am not sure if the file size also affects playback. Can anyone tell me if either of these boxes can play these without a problem? Currently I can play all of them without stuttering on my laptop but not in 3D yet. Also, what software can easily convert 1080p 'FULL' SBS to HALF SBS or even 720p?
Rodney538 is offline
post #99 of 152 Old 01-10-2012, 05:08 PM
mkoss's Avatar
the 3D creator will output dlp Link 120 Hz under 2 conditions. Viewing sbs half 3D and 2D to 3D. I use it this way with my acer H5360. It DOES NOT output 60HZ in dlp mode.
mkoss is offline
post #100 of 152 Old 01-11-2012, 08:48 AM
Rodney538's Avatar
Just curious what you are using to play those files...WDTV, Panansonic 3D bluray player, etc? So Full Sbs won't work with the 3D creator? Does it matter if the files are 720p as compared to 1080p?
post #101 of 152 Old 01-11-2012, 10:40 AM
I turn my WDTV Live on and start to play my HALF SBS MKV. Then you MUST push the SBS button on the 3D-XL. The HD66 projector will see the input as 120hz and the 3D options will be selectable
You cant just play the SBS MKV as the WDTV LIVe is only outputing 60hz, its the 3D-XL that sends out the 120hz signal that the projector NEEDS to seefor the 3D options to become available
(Rodney538) : The WDTV Live will play HALF-SBS only, it will not play FULL-SBS or Bluray ISO's. I am using the WDTV Live right now, but lately I am finding it hard to get HALF-SBS files since FULL-SBS seem to be taking over.
post #102 of 152 Old 01-11-2012, 01:58 PM
unit came in today...unboxing.
Its a bit smaller than I thought it would be.
Back panel...
Comes with glasses and quick start card...
Im mainly wanting to see if I can feed it (3dxl) a converted 2D to 3D signal from the monoprice unit
BRB, Im headed downstairs to hook it all up...fingers crossed!!
post #103 of 152 Old 01-11-2012, 03:10 PM
lewis3845's Avatar
I just got my 3d-xl and it works great with my hd66. The 3d menu is available and I'm using the monoprice to send sbs to the 3d-xl with no problems I have the optoma glasses and my cinema eagle 501 or 502 I can't remember,but the 3d is grteat and I actually prefer the $40 eagle cinema glasses over the big bulky ugly optoma's.
lewis3845 is offline
post #104 of 152 Old 01-11-2012, 03:11 PM
lewis3845's Avatar
So optoma has stopped the ability of other 3d converters in newer firmware. You must buy the 3d-xl if you have a newer hd66 with the newer firmware if you want 3d.
post #105 of 152 Old 01-11-2012, 03:22 PM
DITTO!!! Glad we can watch a lil 3D finally...been a lil frustrating but fun
post #106 of 152 Old 01-11-2012, 03:25 PM
optoma glasses are pretty horrible LoLz!
are you using the 2d - 3d conversion to get your signal?
any quick sources for SBS content to test out??
post #107 of 152 Old 01-11-2012, 03:38 PM
lewis3845's Avatar
I'm using the 2d to 3dtv option on the monoprice that makes sbs out of the source and I have some sbs movies on my usb drive to use on my bluray players usb port. I wish I had a 3d bluray, but I don't . The optoma glasses are huge, why are they so big and why don't they fold, I'm not kidding I like my $40 eagle cinema glasses better than the optoma's.
post #108 of 152 Old 01-11-2012, 03:46 PM
oh, ok.... I think im going to return my 3d bluray to recover sum of the cash spent. Ive got The PS3 that will also play AVI files....so I should be good.
Optima glasses=comical....and reserved for that "special houseguest" LoL!!
quick question before I head back downstairs...am I missing sumthing or does the 3dxl not have a pass thru mode?
post #109 of 152 Old 01-11-2012, 04:17 PM
lewis3845's Avatar
well it's got 2 hdmi inputs so you could use 2 sources, but no it don't have a straight pass-thru and I will say this about the optoma glasses they do have a better contrast ratio than my cheaper ones and If you do have the ps3 then it can played bluray 3d as well.
post #110 of 152 Old 01-11-2012, 04:42 PM
lewis3845's Avatar
Lol paperchaser your gonna save them for a special house guest. My wife was the first to try them and I busted out laughing lol not so smart especially since she paid half for the 3d-xl.
post #111 of 152 Old 01-11-2012, 05:19 PM
Kingcarcas's Avatar
Quoted: 26 Post(s)
Liked: 38
Well that's a relief, i had pretty much abandoned the idea of 3D with my H5360.
So glasses, monoprice, ps3 and i'm set?
Kingcarcas is offline
post #112 of 152 Old 01-11-2012, 05:27 PM
lewis3845's Avatar
Yes the monoprice should work fine on your acer h5360 the only thing you can't do is send the monoprice 3d creator frame packed so you can't play a bluray 3d movie if you want to do that you must purchase a 3d-xl or viewsonic 3d adapter,but yes you can convert your dvd's,2d blurays and games to 3d using the 2d to 3d-dlp mode or if you have sbs 3d content the 3d to 3d-dlp mode, If you happen to have a panasonic bluray player model that outputs sbs you could convert bluray 3d to sbs and use the monoprice that way.
post #113 of 152 Old 01-11-2012, 05:29 PM
canuck's Avatar
So, I'm still left wondering if I can get by attaching the monoprice directly to my hd66.
My firmware allows me to toggle the 3D settings without any converter attached. It allows me to do this with my wdtv as the active input over HDMI at 50 or 60hz.
canuck is offline
post #114 of 152 Old 01-11-2012, 06:12 PM
lewis3845's Avatar
if you can access the 3d menu at all times then the monoprice unit will work for you.
post #115 of 152 Old 01-12-2012, 06:36 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Glad I went with the Acer then. This does suck for people that have other converters like the VIP 3D Theatre.
Ronomy is offline
post #116 of 152 Old 01-12-2012, 03:30 PM
mkoss's Avatar
sounds like grounds for a major complaint against Optoma for doing this kind of crap.
mkoss is offline
post #117 of 152 Old 01-12-2012, 05:48 PM
canuck's Avatar
So if my unit lets me toggle the 3D menus all the time, I'm wondering if I can use one of the cheaper Chinese units that output 60hz?
canuck is offline
post #118 of 152 Old 01-12-2012, 06:34 PM
No
Because the 3d on in the menu is only to turn the dlp link on
The projector needs 120hz input t go in 3D
You don't need to turn the 3D to on in the menu if your not using dlp link glasses
Just get a 120hz frame sequential input and the 3D will work
post #119 of 152 Old 01-12-2012, 06:53 PM
lewis3845's Avatar
I don't really know if the cheaper chinese converters would work or not, if they put out 60hz or 120hz. The ones I seen that have the 3d-dlp mode I would assume to put out 120hz, but I don't know and I think you would be taking a gamble.
post #120 of 152 Old 01-12-2012, 06:54 PM
lewis3845's Avatar
You need 120hz for 3d not 60hz.
Reply 3D Tech Talk
View Sonic 3d Hd Video Processor Vp3d1 , Acer H5360 3d Dlp Projector , Optoma 3d Xl Converter Box For 3d Video And Gaming , Optoma Hd66 Dlp 3d Ready Home Theater Projector , Panasonic 3d Blu Ray Player Dmp Bdt210 , Optoma
