3D Glasses for Samsung LED - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2012, 02:51 PM - Thread Starter
mr_raja's Avatar
Hey all,
Need some advice from all of the AVS gurus. I need to buy a pair of 3D glasses for my Samsung C8000 LED (2010 Model). I was looking in to NXG but seems like there arent many sellers on Amazon selling those. Came across 3Active instead but didnt find too many reviews for them, not as many as NXG. So now I am in a dilemma. Which one would you guys recommend/suggest? The NXG NX-3DGR or 3Active?
Here are the links to the ones that I found:
3Active:
http://www.amazon.com/3ACTIVE-Glasse.../dp/B004Z8VC8M
NXG:
http://www.amazon.com/NXG-Technology...255311-9406223
Thank you all in advance for your help.
mr_raja is offline
post #2 of 5 Old 01-19-2012, 12:47 PM - Thread Starter
mr_raja's Avatar
Umm... So I am guessing no one used either one of these brands.... Or no one cares.
mr_raja is offline
post #3 of 5 Old 01-19-2012, 09:09 PM
doubledown808's Avatar
I'm in the same boat. 2010 Sammy, looking for a new pair.
doubledown808 is offline
post #4 of 5 Old 01-19-2012, 11:16 PM
Robut's Avatar
Originally Posted by mr_raja View Post
Hey all,
3Active:
NXG:
I have a un55c8000 display. I have four kinds of glasses, Samsung not rechargeable, Samsung rechargeable, Sony playstation glasses and NXG. Of those, the NXG's work the best. They are comfortable, don't reduce brightness as much and have less crosstalk. I'm anxious to try x104's.
Robut is offline
post #5 of 5 Old 05-22-2013, 02:19 PM
zeonstar's Avatar
I was looking to buy some 3D glasses for my Samsung C8000 and I came across the 3Active ones. I just noticed they seem to say they aren't compatible with the C8000 models? Can anyone confirm that? I don't see why they would work with the 7000 and 9000, but not the 8000.
I been researching all morning between Quantum 3D G5s, Ultimate3DHeaven's, and now the 3Active. I think 3Active will be the winner...if they're compatible.
zeonstar is offline
Reply 3D Tech Talk
