Egreat Cheap EBay 2d to 3d Converter Box (please help) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-30-2012, 11:02 AM - Thread Starter
justpassedu's Avatar
Quoted: 60 Post(s)
Ok so I was on eBay and found a cheap 2d to 3d convertor and said to myself for $54 I can give it a try , I can't post a link to it on here but if you go on eBay it is the egreat 2d to 3d converter box , I will post the specs below , my question is if it works well what can I expect from it? I will be using it to try and do 2d to 3d conversion on my non 3d 55" toshiba LCD set , the tv is fairly new , It comes with the basic blue and red glasses. I have a xbox 360 and ps3 aswell. Will this somewhat look good over just watching hd tv , will the 3d add to watching movies , shows and possibly gaming or will it be a disappointment ? Is there any better glasses for what I am doing ? Thankyou and please try and help me out , I am sorry for the newb questions , I couldn't pass up trying this since it was so cheap , who knows if it even works...
◆Plastic case, top and bottom have Cooling holes, well-ventilated
◆Fanless design, super quiet
◆The first -class hardware design, the reasonable layout and exquisite workmanship of PCB, guarantee the stable and high efficiency working, at same time, used the unleaded materials for the ROHS.
◆Any 2D movies can be converted to 3D image freely.
◆Support 3D image converted to 2D movies
◆Virtual 3D effect can be enhanced.
◆3D level can be adjusted from strong/middle/weak three grade.
◆Display equipment: 3D TV, 3D projector. 2D normal TV.
◆HDMI1.4 output
◆Compatible with HDMI1.4 / HDMI1.3 / HDMI1.2 / HDMI1.1.
◆Support SBS-H, anaglyph two different 3D signal output to 3D TV.
◆Support L/R signal output to 3D projector.
◆Support anaglyph signal output to 2D TV.
◆3D video output format can be up to 1080p 60Hz
◆3D mode can be switch from five different mode: R/C,SBS-H,L/R, 3D turn off, A/B.
◆ Size:85*56*18MM
Description of the main output port performance:
Video output port:
◆HDMI1.4 1080P output
Video input port:
◆5V/1A power input,inside is plus ,outside is minus
INCLUDES:
1 x 2D to 3D convertor box
1 x HDMI cable
1 x User manual
2 x 3D glasses (red & blue)
1 x Euro Type Power adaptor
justpassedu is offline
post #2 of 2 Old 03-14-2012, 12:10 PM
brzez's Avatar
Have you received and tried this converter?
brzez is offline
Reply 3D Tech Talk
