Ways to avoid replacing my receiver for 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-07-2012, 07:38 PM - Thread Starter
Sundance's Avatar
I am hearing that there are ways to use my current Onkyo SR606 receiver that is not 3D ready by splitting the HDMI signal. Run one to the TV (in my case a Epson Powerlite 3010) and the other to the receiver for audio. My question is will any HDMI splitter work ...something like this one:
Or this:
When it says 3D support does that mean it will do what I want to do or simply that it will pass 3D?
Sundance is offline
post #2 of 12 Old 02-07-2012, 08:50 PM
bubbaba's Avatar
I was thinking about this also with my hd66, but I found out that these splitters downgrade the audio to the lowest denominator that is supported, so if your Epson only does 2 channel audio that is all you will get to your receiver.
bubbaba is offline
post #3 of 12 Old 02-07-2012, 10:05 PM - Thread Starter
Sundance's Avatar
The Epson will not figure into the equation. The source from the blu-ray player will be split, one going direct to the receiver from the player and the other HDMI going to the projector for picture only.
Sundance is offline
post #4 of 12 Old 02-07-2012, 11:18 PM - Thread Starter
Sundance's Avatar
What is this??????????????
Sundance is offline
post #5 of 12 Old 02-08-2012, 01:27 AM
nosys70's Avatar
that's correct, HDMI is bidirectional signal.
So the screen is feeding back to the player some information called EDID.
http://en.wikipedia.org/wiki/EDID
Problem is when you have a splitter, there is also several EDID information.
As said the lowest common feature (resolution, audio channel) is adopted.
So for example if you connect an full HD screen and an HD ready screen on the splitter, both screen will display the lower HD ready resolution.
same for sound
nosys70 is offline
post #6 of 12 Old 02-08-2012, 12:37 PM
Rolls-Royce's Avatar
Quoted: 244 Post(s)
Liked: 371
Actually, it will. As nosys70 explained, splitters report the EDID of the least capable display it's connected to back to the source. That way the least capable display doesn't get sent something it can't handle. There is a Gefen splitter that will always report the most-capable display's EDID, but it's $$$.
Even if you could get the splitter to report a 1.4/3D capable device, there's another potential problem. Older 1.3 receivers have issues decoding the sound from 3D Blu-Rays because that sound is encoded in a different part of the data stream than that used by regular 2D Blu-Rays. Most simply don't produce sound at all even if they can pass the 3D video.
One workaround is to use a Panasonic 310 player. It has dual HDMI outs just for situations like yours. One is 1.4 for video and audio while the other can be set to output 1.3-formatted audio only.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #7 of 12 Old 02-08-2012, 01:00 PM
TrickMcKaha's Avatar
A pretty good solution is to use an optical digital connection for your sound to the receiver and use a HDMI for the video, running the cable direct to the TV or projector bypassing the receiver when you are watching 3D. You get Dolby Digital 5.1 sound or 5.1 DTS and it sounds good. You don't get the lossless sound formats that way, but you save hundreds of dollars. You can use HDMI for sound and video through your receiver for any non-3D material and have lossless sound then. You keep your HDMI connected to the receiver most of the time, but when you want to watch a 3D Blu-Ray you unplug the HDMI from the receiver and plug it directly to the Blu Ray player. You might also have to tell the Blu-Ray player to output sound through optical cable to your receiver if it can't just always be doing that.
You'll find you can hardly tell the difference between Dolby 5.1 and lossless sound, if you are like me, and I sure like sound.
TrickMcKaha is offline
post #8 of 12 Old 02-09-2012, 09:55 AM
g4ses1's Avatar
I ran into a similar issue. I have a Yamaha RXV-3800 HDMI 1.3 and just bought a Panny vt30. I ran my cable (Fios) through the reciever and have absolutely no issue with 3D content from the cable box, the Yamaha passes it just fine. As far as 3D Blueray goes I use a PS3 and ran an optical cable to my receiver and an HDMI to the Panny. Once again no problems at all. I would test running the 3D signal through the Onkyo before anything else.
g4ses1 is offline
post #9 of 12 Old 02-10-2012, 09:40 PM
falafala's Avatar
Quoted: 23 Post(s)
i faced exactly same problem when i got by 3010 and my onkyo is not 3d ready....in my reserach i found that you cannot use a hdmi splitter because hdmi protocol will pick least common denominator in capabilities if you connect 3010 and a receiver via a splitter to your 3d bluray player
if you dont care about HD audio you can try the optical cable aproach
i cared, so got a dual HDMI bluray player like samsung 6700 or panasonic 310...
falafala is offline
post #10 of 12 Old 02-11-2012, 07:56 AM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
I can run 3D through my Onkyo 607 (1.3/"not 3D capable") in SBS format with HD audio, NO problem. I can't see any difference between SBS and FULL 3D in pq.--looks identical to me. This is with my 3010's 3D format set to SBS of course.
Ed
old corps is offline
post #11 of 12 Old 02-11-2012, 06:23 PM
Quoted: 244 Post(s)
Liked: 371
Ed
This may be because some forms of 3D SBS such as those used by cable and satellite providers are actually 1.3 format signals that the older receivers can pass and decode.
...Royce...
post #12 of 12 Old 02-11-2012, 08:24 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
I'm talking about Bluray 3d from my Panny 210 player. When I select SBS format with the Panny and 3010 pj it works just fine and also provides HD audio.
Ed
I've also compared running "Full" 3d directly to the pj and with the same content/same scenes can detect no difference in pq. I just can't get HD audio
when I run it in "Full 3d" because the Onkyo won't pass that through. In that case I have to use toslink/optical for audio, which still sounds excellent.
Reply 3D Tech Talk
