3D screen size ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-20-2012, 06:45 PM - Thread Starter
The big picture's Avatar
I was wondering if there is a chart or a general opinion on how large of a screen you can use with a 720p 3D projector before it is too large and the 3D image breaks down ? Also is the ideal seating distance for 3D viewing different than 2D viewing ? Is being a little closer to the screen better when viewing 3D content ?
The big picture is offline
post #2 of 4 Old 04-20-2012, 11:09 PM
Augerhandle's Avatar
Quoted: 748 Post(s)
Liked: 649
Yes, yes, and YES!
The 3D image doesn't "break down", but at a certain size or distance, one can see the difference between 720P and 1080P.
It is recommended that one sit closer for 3D viewing. For example, the recommended viewing distance from a 65" display is:
2D > 8 ft 10 in
3D > 6 ft 07 in
A problem with 3D can be that the 3D effect is broken / cut off at the side edges of the screen. Sitting closer helps by moving the sides of the screen into one's peripheral vision, where this will not be noticed. This helps with viewer immersion into the movie, as well.
http://www.practical-home-theater-gu...-distance.html
http://www.best-3dtvs.com/guides/bes...wing-distance/
Of course, these are just guidelines.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #3 of 4 Old 04-21-2012, 01:45 AM
Airion's Avatar
Liked: 61
I happily sit 7 feet away from a 90" screen when viewing 3D on my 720p projector. Any closer and the frames of my 3D glasses would be cutting off the edges of the image. At the same distance in 2D I can see a screen door effect and the 720p image is clearly lacking resolution, but in 3D, it magically disappears.
The only minor issue with sitting so close is I can sometimes see some ghosting when looking through the edges of my glasses. If I were to move back more of the image would be seen in the center of the glasses where there's no ghosting, but I'd rather just sit close and move my head slightly when I really have to!
Airion is offline
post #4 of 4 Old 04-30-2012, 01:42 PM
JOHNnDENVER's Avatar
I tend to agree with the above, 8'-ish at 106" diag is about the limit for my glasses frames if I lean forward much at all I seem to get some cut off on the edges in 3D.
JOHNnDENVER is offline
Reply 3D Tech Talk
