Official Omega 3D passive projection system thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #541 of 772 Old 01-20-2014, 10:22 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Originally Posted by Soulnight View Post
How? Where do you download the firmware? How do you install it?
you need something to do the flash (cable/card rs232). but i don´t recommend it if you have to ask how do i install it.
you can´t download the firmware.
you can ask for it if you own a geobox.
Vaan Janne is offline
post #542 of 772 Old 01-20-2014, 12:05 PM - Thread Starter
Quoted: 13 Post(s)
image here
motorman45 is offline
post #543 of 772 Old 02-01-2014, 09:29 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Motoman. Are the new filtters due to release gonna enhance the dlp color balance also or are they just for the dlp ?
post #544 of 772 Old 02-02-2014, 11:06 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #545 of 772 Old 02-06-2014, 01:00 AM
zorg43x's Avatar
Quoted: 31 Post(s)
please, keep us informed! i am very interested.
do you know of any LCoS or SxRd with higher lumen output? I need at least 4200...
Originally Posted by Vaan Janne View Post
http://www.hometheaterhifi.com/projectors/projectors-reviews/optoma-hd8200-dlp-projector/all-pages.html
at conclusion -->
is there color gamut otherwise good for omega ?
Im soon gonna order these babies
So after all you are going the How-I-Learned-to-Stop-Worrying-and-Love-the-RBE way? biggrin.gif
zorg43x is offline
post #546 of 772 Old 02-06-2014, 09:28 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
i might have. My wife filled all the boxes of things that you should not have if you buy dlp, so i dumped rainbow city and bought mitsubishi hc5.
if i only had the money to buy another when the new omega filtters for lcd/sxrd hit the shelves.
I looove the 2d on hc5. 3d is total utter crap(came as no suprice its bad, but not that bad). Flickery and ghosting. Much poorer than my older linear setup with ax200's and polarisers.
post #547 of 772 Old 02-06-2014, 12:07 PM
zorg43x's Avatar
Quoted: 31 Post(s)
good for you. the first thing on a (1ch) DLP i see is the rainbow. bad for me :/
wwoooooou if i had the money to buy a dual 3DLP setup, that would be a complete different story biggrin.gif
zorg43x is offline
post #548 of 772 Old 02-07-2014, 12:05 PM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
did anyone every find out how much the VNS 303 box will be. what are the main differences between it and the 501
space2001 is offline
post #549 of 772 Old 02-08-2014, 11:00 AM
imbloodyskint's Avatar
http://www.vnstw.com/en/Upload/News3/News-2014261644564.pdf
imbloodyskint is offline
post #550 of 772 Old 02-15-2014, 08:32 PM
cerealk's Avatar
hello,
i have a problem with my geobox 501 and omega filters
when i am in 1080p 120hz(or 100hz), i have black pixel in red image, just in the red and just with channel A.
in 1080p60hz and 24hz no problem.
i tried :
diferrent output hdmi cables
input geobox with displayport and dvi-d
two gpu cards : gtx 560 and gtx 780
two different boot system with 3 different drivers
it's ok if i change for 16 bits colors but in game it's 32 bits...
two projectors at 1080 60hz in 2d are ok
(I have another problem with inversion of 3d effect (left/right) with somes games)
If you have a solution...
cerealk is offline
post #551 of 772 Old 02-17-2014, 10:57 AM
cerealk's Avatar
Hi,
Problem solved for me with update firmware of geobox !!
Big thanks at Steve Wang (vns company)
cerealk is offline
post #552 of 772 Old 02-17-2014, 08:53 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Just wonder how you could even been in 120hz mode. 501 did not support it before the update, or is there another 120hz update
post #553 of 772 Old 02-18-2014, 01:31 AM
sid-6581's Avatar
@motorman45: I have two Epson EH-TW4400 (http://www.projectorcentral.com/Epson_Europe-EH-TW4400.htm) and now I want to purchase the Omega3D system. However, I'm not sure wether to buy the small or large LCD kit. I want to install it in front of the lens with some clamps (hopefully finding the right angle). Or would it be easier to install inside? Could I still watch 2D after that? Thanks!
sid-6581 is offline
post #554 of 772 Old 02-18-2014, 04:51 AM
cerealk's Avatar
This is another update !
cerealk is offline
post #555 of 772 Old 02-18-2014, 05:29 AM - Thread Starter
Quoted: 13 Post(s)
the update released recently for the 501 supports 120hz. it was talked about back a little in this thread.
post #556 of 772 Old 02-18-2014, 05:44 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
yes i know but there has been another update after that if understood cerealk correctly. I also have update to make 501, 120hz compatible,
i have not flashed it yet. But i don' t know if there s any point of flashing it if there has been released yet another version
post #557 of 772 Old 02-18-2014, 05:50 AM
sid-6581's Avatar
the small LCD kit will work fine for external. i would recommend not doing the internal mounting on an LCD. i have had several costumers use the projector you have chosen and loved how our system works with them.
you can watch 2d with the filters in place if the two images are aligned well enough but its easier to flip one filter out of the way and watch 2d with one unit on. alternate between the two to average the bulb life between the two units.
do you need a demultiplexer ??
Isn't it harder to get the angle right when installing the filter externally? And yes, I do need a demultiplexer, however I might have a source for a G501 or G201 already. If that doesn't work out I would get back to you.
sid-6581 is offline
post #558 of 772 Old 02-18-2014, 06:33 AM - Thread Starter
Quoted: 13 Post(s)
i think the update you have is the latest. steve could clear this up.
post #559 of 772 Old 02-18-2014, 06:40 AM - Thread Starter
Quoted: 13 Post(s)
no its actually easier to get the angle of the filter to work well externally. if you look back at the posts on internal mounting i think i mentioned how critical the angle is in internal mounting, if not i did now smile.gif when the F# of the light beam or speed of the beam is very fast the filter becomes more sensitive to angle. it can work well in a DLP to internally mount the filter and its the only good method when using a short throw projector like the BenQ W1070 as externally mounting the filter will not give good results due to the trow.
well we have 201's here and one 501 left ( thought it was sold but they backed out )
post #560 of 772 Old 02-22-2014, 12:10 PM
Soulnight's Avatar
Quoted: 272 Post(s)
Liked: 178
No it's not. Cerealk contacted steve because of his problem with the red and steve made a new firmware available to correct the problem.
But at the begining, cerealk had already what you're naming the new firmware for 120hz.
Soulnight is offline
post #561 of 772 Old 02-23-2014, 09:00 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
i knew it....
maby i should contact steve also to get the newest...allthough i have not even flashed the first 120hz update.
post #562 of 772 Old 03-18-2014, 04:06 AM
voldemar72's Avatar
These glasses will work with your computer without demultiplexer ?
http://www.ebay.com/itm/151198323085?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
voldemar72 is offline
post #563 of 772 Old 03-18-2014, 06:55 AM - Thread Starter
Quoted: 13 Post(s)
no they wont work without the projection filters and a pair of projectors. the listing was made for someone who wanted 2 more pairs that already had a system
post #564 of 772 Old 03-18-2014, 07:00 AM - Thread Starter
Quoted: 13 Post(s)
i am testing the new Z version of my omega 3d system. it should have very good eye to eye color balance especially for LCoS like JVC. i will be looking for someone with LCoS projectors to do some beta testing soon that is willing to provide some feedback.
new frame too
post #565 of 772 Old 03-18-2014, 07:02 AM - Thread Starter
Quoted: 13 Post(s)
proto of new frame , 63mm inter-ocualr instead of the 69mm of the theater frame ( one key to less back reflection ) . lighter better fitting for kids as well as adults, added light blocking to bottom edge and along ear stalk and they fold
this will be the frame using the new Z filter set
post #566 of 772 Old 03-18-2014, 07:20 AM
voldemar72's Avatar
:)Цитата:
не Сообщение от motorman45 Посмотреть сообщение
не они не будут работать без проекционных фильтров и пары проекторов. список был сделан для тех, кто хотел еще 2 пары, которые уже имели систему
Я понимаю, что мне нужно два проектора и два фильтра
Я спросить, есть ли необходимость демультиплексор?
http://www.vnstw.com/en/products_view.asp?ID=105&BKID=68
post #567 of 772 Old 03-18-2014, 07:53 AM - Thread Starter
Quoted: 13 Post(s)
?? are you looking for a 501 geobox ? i still have one on hand
post #568 of 772 Old 03-18-2014, 08:03 AM
voldemar72's Avatar
? Вы ищете 501 Geobox? я до сих пор один под рукой
нет
 Переводчик, трудно, вы меня не понимаете
Я спрашиваю вам нужно это необходимым?
post #569 of 772 Old 03-18-2014, 12:54 PM - Thread Starter
Quoted: 13 Post(s)
image here
voldemar72 likes this.
post #570 of 772 Old 03-18-2014, 10:26 PM
voldemar72's Avatar
no you dont need a demultiplexer to split a video to two projectors, you can use a PC with a dual output video card and a program like stereoscopic player. but you will need two projectors and the projector filters along with the glasses.
Thank you! About what I asked!
Reply 3D Tech Talk
