Official Omega 3D passive projection system thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #631 of 764 Old 09-01-2014, 06:25 AM
Free_born's Avatar
Originally Posted by sulakd View Post
With Omega filters on a dual-projection passive 3d setup, what do you do if you are not watching something in 3d? Do the Omega filters have to be moved out of the way? I read somewhere about internally mounting the Omega filters, and it seems that would be a problem if they have to be moved for 2d viewing.
I will be setting mine up soon and will internally mount the filters in two Benq W1070 projectors. I intend to always run both projectors for 2D and 3D. My hope is that the dual projectors provide enough light that I can forget the filters are in place.
Eventually I plan to use two Benq SH940's for my game / theater room with internally mounted filters but by the time I'm ready a better projector set may be available.
If you look back to Motorman's post a page or two back you'll see he keeps his filters in place for 2D viewing on a 170" screen.
Free_born is offline
post #632 of 764 Old 09-01-2014, 06:49 AM
Liked: 0
Can anyone help me I have a str-k750p sony surround sestem and my CD button stays on so I can't change my channels what can I do thanks
Judson Cass is offline
post #633 of 764 Old 09-01-2014, 11:58 AM
imbloodyskint's Avatar
I have 2 x w1070 stacked setup (one ontop of the other)
Filters fitted inside, vns geo 201 demuxer. one has slight green tinit, the other has slight violet tint, but can adjust MOST of that out when just using one for 2d video.
Also,
one appears to be slightly dimmer/darker, but again just adjust contrast or brightness to compensate.
To be able to get them to line up really (Not perfect) I removed one of the w1070's adjuster screws sliding cover to get both of them as close as possible so not having to use alot of offset.
Only issue I find, is I now get alot more light leakage coming out of the front and side vents which show on the ceiling and side wall, seems the filters maybe the problem as wasn't anywhere near as bad before fitting them inside the w1070's.
One day I WILL make something to sit infront of the vents which will defuse/block the light, yet still allow the heat to escape.(using black spandex and brackets)
imbloodyskint is offline
post #634 of 764 Old 09-02-2014, 10:09 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Just gamed metro REDUX with my sli gtx660ti rig and omega setup. MAN IT BLEW MY MIND... i coul not stop saying wow this is frikin´awsome.
I can nothing but recommend the HC5 dual rig with omega.
imbloodyskint likes this.
Vaan Janne is offline
post #635 of 764 Old 09-05-2014, 06:55 PM
stee1hed's Avatar
Liked: 0
As stated in another post, each filter adds it's own tint to the picture. For 2D content the best picture for me comes from using 1 projector and removing the filter from the front of it.
Some people do both projectors with the filters on but they must be aligned very close for that, closer than when watching something in 3D and you're burning both 'non-cheap' bulbs.
It's a personal preference. The only right way is what makes you happy.
stee1hed is offline
post #636 of 764 Old 09-09-2014, 04:26 AM - Thread Starter
Quoted: 13 Post(s)
image here
motorman45 is offline
post #637 of 764 Old 09-09-2014, 02:45 PM
Kxtr73's Avatar
I'm thinking about dual projector passive 3d from long time. However I have many doubts how to spend my cash well. PS. I can use only LCD projectors. Bulb or LED DLP PJ-s give me eye strain.
My PC: AMD Phenom X4 965 BE/AMD Radeon 7770 is capable to handle Tridef playing in 2x full 720p or SBS 1080p . Sony vpl-dw120 1280x800 3xLCD business projector (not 3d) which I have gives satisfactory cinema image. (to have better black level I painted my wall on grey). Gaming: input lag is great, but 800p is rather too low and unsatisfactory vs playing on monitor.
1. grab another new Sony vpl-dw120 for 500USD or buy used (teoretically on paper very similar) Epson TH-TW450 for 200 USD. Set up at first DOLBY 3D with colour correction made by software (free testing becouse I bought 3 glasses for cheap). And have extra 2D playing in 2560x720. Next plan -> Omega System.
cons: still 800p and everybody is going to 1080p now
2. or sell my Sony and buy Epson 2030 (TH-TW5200) for 870 USD new/562 USD used - no lens shift too.
Before selling Sony try to made 720p passive. Eventually buy another used one in future to made passive 3d 1080p cinema.
Higher 1080p LCD PJ are too costly and DLP is not an option for me (eye strain).
pro: 1080p in 2D, 1080p 24Hz 3D, a little more detailed 1080p 60HZ SBS then 2x720P 3D
cons: 100 ms input lag and shutter glasses which I don't really like (head pain, eye strain)
3. Wait becouse there is not good solution without purchase a new powerful PC and 2 more expensive LCD (with better input lag) (SXRD is out of my league) and investing in 720p path especially without lens shift is obsolete.
What do You think ? I have temptation to buy 2030 used/or TW-450 used for even less, but both PJ could be somewhat different in many ways to my Sony and without lens shift. Maybe second Sony is safer purchase but more costly when going this way.
Still I had to live with some little trapezoid distortion in 3D when projecting 130' from 4 metres. (Even +-1 keystone deteriorate picture too much for me). Simply I don't want to waste my money on experiments.
Kxtr73 is offline
post #638 of 764 Old 09-10-2014, 04:52 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #639 of 764 Old 09-11-2014, 12:57 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
motoman.
no info on those new filtters ? are them cancelled ?
i don´t remember if i ask this already but, the bjomejag said i have no advance with lcd versions of the omega filtters over dlp version (i have), do you agree ?
i have the mitsubishi hc5 (Sxrd).
post #640 of 764 Old 09-13-2014, 09:40 AM
Kxtr73's Avatar
Thank You motorman45 for fast answer. I bought finally used Epson EH-TW5200 in EU (Epson 2030 in US) for 2/3 price of new one (for 560 USD). I was very lucky becouse it was totally new PJ without any sign of use in perfect condition.
First I tried stacking of mine Sony 800p with new Epson 1080p with Dolby glass filters (both in 1080p). After 5 minutes I made almost perfect alignment. Of course colours in every eye was different, but overall effect was good. However I found it somewhat not so comfortable to eyes. Probably not corrected colours, different level of brightness in every eye and a little missaligment made it. Watching 3D Dolby in Cinema I had not such problems. I can use fixes from: DIY DOLBY 1080p 3D, Color correction not really needed... to see how it made situation better.
Then I tried active 3d of Epson. I found it shockingly good for me. More pop then in Dolby and without almost any eye stress. I can't see any crosstalk, but image is a little to dark whith active. So for now I will stick with it. Mayby in future I will go with dual PJ passive to full 3D gaming. Final clue: 1080p is much better then 720p and active 3D is not so bad as I thought
Kxtr73 is offline
post #641 of 764 Old 09-13-2014, 11:33 AM
Liked: 0
Hi,
I am doing video design for a big drama theater production.
We are planning to include 3D section where audience would have 3D glasses on.
Projection surfaces are quite unconventional and we can't use silver screens.
We could go for active glasses, but I don't personally like them and I am not sure how they would perform with live actors.
Omega filters seems like promising passive option.
Have any one of you tried those filters with big dlp projectors? For example with Christie digital or Barco, 18K or higher.
And do you have any experience about non white (black or blue) projection surfaces?
Jouka is offline
post #642 of 764 Old 09-19-2014, 06:38 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #643 of 764 Old 09-19-2014, 04:56 PM
Liked: 0
Originally Posted by motorman45 View Post
I have an end user who has done exactly this. my filters will work perfectly for this kind of application. as long as a surface has some reflected light it will function.
as far as large projectors, my system was originally designed and used in cinema and works great with these untits. in fact better than UHP lamp home theater untis. i have large sets of filters that fit over the end of a pair of large Barco projector lenses.
its not a cheap system but it is the only way to do a stereo projection like this other than shutter glasses. PM me for details
Great. Thank you for the info. I would love to find a passive solution for this, because I have my doubts how the shutter glasses function with stage lighting and real live people in stage.
Unfortunately my post count does not allow me to PM you, but could you PM your email address and I can forward it to the people how take care of the technical arrangements for this production.
Jouka is offline
post #644 of 764 Old 09-24-2014, 05:33 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #645 of 764 Old 10-22-2014, 09:21 AM
Free_born's Avatar
I received my Geobox G-501 last night to complete my Omega 3D setup. I'm running two Benq W1070 projectors and mounted the filters internally just past the condenser lens, cutting the filters from the experimenters kit and using a little high temp rtv silicone adhesive.
For 1080p/24 frame packed 3D it looks incredible! I found tearing if I sent 24p straight through to the projectors but by letting the geobox send 1080p/60 to each projector it looked great. I did not have much time last night but watched scenes from Gravity and Frozen.
I am quite pleased for movie use. Next up is to figure out how to get the 1920 X 1080 X 120Hz Nvidia 3D working
Free
post #646 of 764 Old 10-22-2014, 05:31 PM
Were exactly are they in the W1070?
post #647 of 764 Old 10-23-2014, 09:00 AM
Free_born's Avatar
Hello,
I may be using the wrong term. I mounted my filters in the same location philiwahnilli did in post #233 on page 8 of this thread. I actually glued mine to the plastic cover which houses the spherical mirror, right against the opening the light comes into from what I called the condenser lens.
I received an email from Steve from vns last night as well and have dual link DVI working on my geobox now. Until I get a display port cable it offers me 1920 X 1080 60hz 3D (60Hz per eye).
Once I have a display port cable then I'll have sound as well as the high frame rate
Free
post #648 of 764 Old 11-09-2014, 12:19 PM
trgraphics's Avatar
Is there a method for reducing the reflections from the inside of the glasses? I have added foam to the frame and done away with external reflection. Now, I get reflections from my face in the lenses. Any thing that can be applied to the inner part of the lease to reduce this effect?
trgraphics is offline
post #649 of 764 Old 11-12-2014, 05:33 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #650 of 764 Old 11-19-2014, 08:27 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #651 of 764 Old 12-04-2014, 12:31 AM
Chrodarcniss's Avatar
I hate to say but we will be out of stock soon for a little while on optics. our production will be interrupted for a little while while, if anyone is interested in a kit i would get your order in now while i have some stock
Hi Motorman, is production still stopped or running again?
Chrodarcniss is offline
post #652 of 764 Old 12-04-2014, 06:15 AM - Thread Starter
Quoted: 13 Post(s)
image here
post #653 of 764 Old 12-05-2014, 02:33 AM
zorg43x's Avatar
Quoted: 27 Post(s)
Did you try it with the new laser projectors eg. Sony VPL-FHZ55? Can they be used or they have too narrow spectrum?
zorg43x is offline
post #654 of 764 Old 12-09-2014, 10:29 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
I wen´t to see Panasonic 6000. Oh my god the active 3D, atleast for that particular projector was CRAP compared to my dual HC5 omega setup.
If any one sels his LCD version of omega filtters. im interested to try. I do have dlp versions that are claimed to me better for Lcos by some
but i refuse to believe. Offer them to me in good price
post #655 of 764 Old 12-11-2014, 12:22 PM
philiwahnilli's Avatar
New Sony Laser projector
Hi,
according to the Sony white paper their technology it not a real pure laser technology like a scanning system an there should be no issue with narrow laser spectra that lasers inherently have.
https://pro.sony.com/bbsccms/assets/...ectors_X1A.pdf
There have been similar hybrid systems using red and blue LED in combination with a blue laser (which was used to illuminate a green phospor). The LED spectra are pretty narrow, so i guess this is an issue with omega 3D filters.
This sony projector uses ONE blue laser to illuminate a white phospor which emits a much wider spectrum than the RGB lasers itself. The PDF shows that the phosphor is just used as the new white light source and is splitted into the primary colors using dicroitic mirrors again, just like "usual" 3LCD projectors do. So Omega LCD filters should work very well, In my opinion.
Best,
phil
philiwahnilli is offline
post #656 of 764 Old 12-11-2014, 12:57 PM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Some one should make a3d compatible bulp with large gamut
post #657 of 764 Old 12-16-2014, 11:46 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
Motoman. Could one get near perfect color balance even with LCD projector if
One would have a display adapter with frame lock on pc and would calibrate each projecor through filter so one cold have spesific color profiles for left and right projector ?
post #658 of 764 Old 12-20-2014, 04:15 AM
clausdk's Avatar
Quoted: 214 Post(s)
Liked: 82
Is anyone using a HTPC with gtx970 using dual dvi output? Just found this thread sounds interesting. I was looking at 2 x benq 1070 to do the job and using a HTPC as the source and L/R splitter rather than the geobox. Recommended or just get the box?
clausdk is offline
post #659 of 764 Old 12-20-2014, 05:39 AM
Vaan Janne's Avatar
Quoted: 49 Post(s)
PM imbloodyskint , if i remember correctly he had 1070 with omega experimental kit internally installed.
Ps. BenQ lens shift is not enough. You kind of need the geobox to Also get the pj's lined up properly, without bigger compromises.
post #660 of 764 Old 12-20-2014, 05:53 AM
clausdk's Avatar
Quoted: 214 Post(s)
Liked: 82
Ok thanks. I guess I can still use a HTPC for playback.
clausdk is offline
Reply 3D Tech Talk
