Problem with 3d subtitles - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-28-2012, 11:30 AM - Thread Starter
-Eli-'s Avatar
This is about a 3d side by side movie. I played it in my 3d lg through my laptop and in order for the 3d to show properly i had to change the setting from left/right to right/left(otherwise the image was kinda blury and it was really tiring to watch). When i tried converting my str with 3dsubtitler, i could only see the subs when the setting was in left/right. So once i fix the video the subs get bad. So i wanted to ask if there is any way to create the subs for right/left with 3dsubtitler, or if anyone knows about another program that can do that..
Thanks in advance :S
-Eli- is offline
post #2 of 2 Old 04-28-2012, 01:34 PM
juniperpansy's Avatar
Quoted: 16 Post(s)
Not sure if this applies to your case or not... but I have a media streamer. The video can be converted to 3D either by the TV or the media streamer. Depending on which one I choose the convert to 3D the subtitles either are blurry or look proper.
If you play around with that it might help.
juniperpansy is offline
Reply 3D Tech Talk
