Ideal position and distance for best 3D watching on a 65inch VT30. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-15-2012, 07:21 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
So i got my 65'' plasma exactly at eye - level when im @ the seating position.
The distance between the TV and seating position is about 2.8 meters.
dazkyl is offline
post #2 of 4 Old 06-01-2012, 07:14 PM
TrickMcKaha's Avatar
Wherever you want to sit is best, and you can always do that at home. I like to sit close - 1 to 1.5 screen width away. On a 65" plasma I might sit 2 meters away.
TrickMcKaha is offline
post #3 of 4 Old 06-02-2012, 04:06 PM
walford's Avatar
As long as you can just see the side edges without turning your head and the image does not look grainy you are not too close.
You are probably not too far to loose any content detail if slightly less then 2 meters and at 2.8 meters the amount of detail lost would be small.
walford is offline
post #4 of 4 Old 06-04-2012, 06:30 AM
nickels55's Avatar
Liked: 36
What's a meter?
I have a 61" HDTV, normal viewing distance about 10-12 feet. With 3D, I get much closer, like 6-7 feet (or 1.8-2.1 meters)
nickels55 is offline
Reply 3D Tech Talk
