SBS 3D viewing with WD-73C9 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-26-2012, 02:03 AM - Thread Starter
Brigganator's Avatar
Hello i have a WD-73C9 dlp set with glasses, emitter and 3d kit and i can watch 3d with my ps3 hooked up no problem, my question is when i try to play a mkv 3d movie all it shows it side by side picture even when its in 3d mode and the only options i have is standard or reverse and on and off for the 3d menu, anyone have similar issue with same tv or similar mitsubishi dlp sets when trying to view SBS 3d video from a souce
(BTW my source that im streaming the 3d content is from my pc to my wd live hub then obviously to my tv.)
appreciate the response guys.
Brigganator is offline
post #2 of 2 Old 05-29-2012, 10:07 AM
GEP
GEP's Avatar
Press the 3D MODE button on the adapter front or the adapter remote to change the adapter to side-by-side. Your source does not add the HDMI 3D type flag to the signal so the adatper's automatic function cannot work. This is why they gave you the manual over-ride by adding teh 3D MODE button.
GEP is offline
Reply 3D Tech Talk
