3d panasonic calibration cheating question?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-02-2012, 09:16 AM - Thread Starter
DerekinMerrick's Avatar
instead of paying someone to calibrate my tv the right way. Can I just copy all this stuff and do it my self? or will it mess things up?
http://www.scribd.com/doc/87081224/P...ration-results
DerekinMerrick is offline
post #2 of 4 Old 06-02-2012, 03:19 PM
Musictechguy's Avatar
I really don't think you'll find this makes much difference
Musictechguy is offline
post #3 of 4 Old 06-03-2012, 09:00 AM - Thread Starter
What calibrating a tv?
post #4 of 4 Old 06-03-2012, 09:59 PM
Augerhandle's Avatar
Quoted: 770 Post(s)
Liked: 663
Calibration can make a huge difference. I dabble as a hobby, and did a quick, so-so calibration on my friends TV last month. He was very impressed, to say the least. As was I. He has a great set (Mitsubishi WD-73840).
The problem with copying someone else's settings is that there can be a large difference in settings between TVs, even two of the same model. Plus, room lighting and user preference play a role. The best you can do with copied settings is hope it improves your set, and doesn't make it look worse.
I highly recommend a professional calibration whether you're serious about home theater or just watch a lot of movies. If you're handy, you can also learn enough to do a pretty good job yourself, though there is a steep learning curve.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Reply 3D Tech Talk
