3D subtitles at 3d tv's like samsung - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-19-2012, 05:04 PM - Thread Starter
fits79's Avatar
Quoted: 46 Post(s)
I was trying to see 3d subtitles to some samsung 3d tv's and the only subtitles i see correctly is the classic srt files but the subtitles was 2D AND NOT 3D.
Here it is some file types of subtitles i try to see if it regonise it as 3d subtitle but nothing happened.
General
Unique ID : 221887995550398801837083185618254603813 (0xA6EE12D070E65C29890F2C986510A625)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Cars2 3d with included subs.mkv
Format : Matroska
Format version : Version 2
File size : 50.9 MiB
Duration : 50s 38ms
Overall bit rate : 8 539 Kbps
Encoded date : UTC 2012-05-08 08:26:26
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 50s 50ms
Bit rate : 6 475 Kbps
Width : 1 920 pixels
Height : 802 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.175
Stream size : 38.6 MiB (76%)
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 50s 38ms
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Delay relative to video : 1ms
Stream size : 9.01 MiB (18%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 50s 38ms
Bit rate : 384 Kbps
Bit depth : 16 bits
Delay relative to video : 22ms
Stream size : 2.29 MiB (4%)
Language : Greek
Default : No
Forced : Yes
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : Greek
Default : Yes
Forced : Yes
General
Unique ID : 192156086096128268347389108269484788465 (0x908FEA805823B491B3893502C9DACAF1)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Immortals 3d(Up-down)(Included pgs).mkv
Format : Matroska
File size : 313 MiB
Duration : 1mn 30s
Overall bit rate : 29.1 Mbps
Encoded date : UTC 2012-05-20 18:58:17
Video
Format : AVC
Format settings, ReFrames : 4 frames
Duration : 1mn 30s
Bit rate : 27.0 Mbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.544
Stream size : 291 MiB (93%)
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1mn 30s
Bit depth : 24 bits
Delay relative to video : 10ms
Stream size : 16.3 MiB (5%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Greek
Default : Yes
Forced : No
General
Unique ID : 248841072057891173366782583270521559360 (0xBB350C15C18E850B8EF4D0C25CB1D940)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Monsters vs aliens (Internal sup subtitles).mkv
Format : Matroska
File size : 360 MiB
Duration : 5mn 2s
Overall bit rate : 9 990 Kbps
Encoded date : UTC 2012-04-12 05:46:35
Video
Format : AVC
Duration : 5mn 2s
Bit rate : 9 599 Kbps
Height : 816 pixels
Display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.256
Stream size : 330 MiB (92%)
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9599 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 5mn 2s
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 23.1 MiB (6%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Language : Greek
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Monsters vs aliens - sbs.sup
File size : 52.8 MiB
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (External idx-sub subtitles).idx
File size : 42.5 KiB
General
Unique ID : 228294729571686873698102241188458967778 (0xABBFF7306F07BFE1BF77DDD773CAB2E2)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (External idx-sub subtitles).mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Overall bit rate : 13.0 Mbps
Encoded date : UTC 2012-04-12 06:24:53
Video
Format : AVC
Format profile : High@L4.0
Duration : 2mn 0s
Bit rate : 11.2 Mbps
Nominal bit rate : 10 000 Kbps
Frame rate mode : Variable
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.225
Stream size : 161 MiB (86%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Stream size : 21.7 MiB (12%)
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (External idx-sub subtitles).sub
Format : MPEG-PS
File size : 12.3 MiB
Duration : 1h 38mn
Overall bit rate : 17.5 Kbps
Text
ID : 189 (0xBD)-32 (0x20)
Format : RLE
Format/Info : Run-length encoding
Muxing mode : DVD-Video
Duration : 1h 38mn
General
Unique ID : 253126540989894705150785881856479426404 (0xBE6E66042C0A2BA191368B902C197764)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (External sup subtitles).mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Encoded date : UTC 2012-04-12 06:17:27
Video
Format : AVC
Duration : 2mn 0s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (External sup subtitles).sup
File size : 46.8 MiB
General
Unique ID : 240660801779494754375352387977529588207 (0xB50D959F16793E5D9AD74B906C80F9EF)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs (Internal idx-sub subtitles).mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Encoded date : UTC 2012-04-12 06:23:03
Video
Format : AVC
Duration : 2mn 0s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.226
Stream size : 162 MiB (86%)
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Stream size : 21.8 MiB (12%)
Default : Yes
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Greek
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs - ass subtitle.ass
Format : ASS
Format/Info : Advanced SubStation Alpha
File size : 91.8 KiB
Text
Format : ASS
Compression mode : Lossless
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs - ass subtitle.mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Video
Format : AVC
Duration : 2mn 0s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs - smi subtitle.mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Video
Format : AVC
Duration : 2mn 0s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\1080P Subtitles\Step up 3d - sbs - smi subtitle.smi
File size : 132 KiB
General
Unique ID : 250915675184130286031709715518896961792 (0xBCC499EA8EED6A458580F4C8514B7900)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\2d subtitles\Cars 2 (Internal srt utf8 subtitles).mkv
Format : Matroska
File size : 116 MiB
Duration : 2mn 1s
Overall bit rate : 8 021 Kbps
Encoded date : UTC 2012-04-12 06:14:45
Video
Format : AVC
Duration : 2mn 1s
Bit rate : 6 352 Kbps
Nominal bit rate : 9 650 Kbps
Height : 802 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.172
Stream size : 91.9 MiB (79%)
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=90 / rc=2pass / mbtree=1 / bitrate=9650 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2mn 1s
Bit depth : 24 bits
Stream size : 21.9 MiB (19%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Greek
Default : No
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\2d subtitles\Step up 3d - sbs (External srt subtitles).mkv
Format : Matroska
File size : 187 MiB
Duration : 2mn 0s
Video
Format : AVC
Duration : 2mn 0s
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 2mn 0s
Bit depth : 24 bits
Default : Yes
Forced : No
General
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\2d subtitles\Step up 3d - sbs (External srt subtitles).srt
Format : SubRip
File size : 71.9 KiB
Text
Format : SubRip
General
Unique ID : 208092390582522835015024369115179036086 (0x9C8D22F9AC2B2047B214E2F7F278ADB6)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\720P Subtitles\Monsters vs aliens - sbs(Internal sup(bd) from BDSup2Sub.jar.mkv
Format : Matroska
File size : 62.4 MiB
Duration : 1mn 1s
Overall bit rate : 8 442 Kbps
Encoded date : UTC 2012-04-15 02:03:46
Video
Format : AVC
Duration : 1mn 1s
Bit rate : 7 634 Kbps
Height : 816 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.203
Stream size : 56.4 MiB (90%)
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1mn 1s
Bit rate : 640 Kbps
Bit depth : 16 bits
Delay relative to video : 8ms
Stream size : 4.73 MiB (8%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Language : Greek
Default : Yes
Forced : No
General
Unique ID : 200110913179964427750166614522128013748 (0x968BF5C1DA1CB6EA94BF4707E5B499B4)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\720P Subtitles\Step up 3d - sbs(Internal idx-sub from BDSup2Sub.jar).mkv
Format : Matroska
File size : 89.3 MiB
Duration : 59s 890ms
Overall bit rate : 12.5 Mbps
Encoded date : UTC 2012-04-15 02:35:23
Video
Format : AVC
Duration : 59s 893ms
Bit rate : 10.8 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.216
Stream size : 76.8 MiB (86%)
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Bit depth : 24 bits
Delay relative to video : 3ms
Stream size : 10.8 MiB (12%)
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Greek
Default : Yes
Forced : No
General
Unique ID : 214100410032746338548059109338056044708 (0xA1123D3444158220A0D54BFA250D30A4)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\720P Subtitles\Step up 3d - sbs(Internal idx-sub).mkv
Format : Matroska
File size : 120 MiB
Duration : 1mn 1s
Overall bit rate : 16.5 Mbps
Encoded date : UTC 2012-04-15 02:18:11
Video
Format : AVC
Duration : 1mn 1s
Bit rate : 14.7 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.295
Stream size : 107 MiB (89%)
Default : Yes
Forced : No
Audio
Format : DTS
Format profile : ES
Codec ID : A_DTS
Duration : 1mn 1s
Bit depth : 24 bits
Stream size : 11.0 MiB (9%)
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Greek
Default : Yes
Forced : No
General
Unique ID : 240814986170533861348363979496597544804 (0xB52B477FB34B1671BBE9B05A8948DF64)
Complete name : C:\Jdownloader things\Movies\3d movies for testing subtitles\720P Subtitles\The adventures of tintin(Internal sup).mkv
Format : Matroska
File size : 83.1 MiB
Duration : 1mn 5s
Overall bit rate : 10.7 Mbps
Encoded date : UTC 2012-04-15 02:11:16
Video
Format : AVC
Duration : 1mn 5s
Bit rate : 8 952 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.180
Stream size : 69.7 MiB (84%)
Default : No
Forced : No
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1mn 5s
Bit depth : 16 bits
Delay relative to video : 24ms
Stream size : 11.8 MiB (14%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Language : Greek
Default : Yes
Forced : No
Why is this happening?
What i can do to see 3D SUBTITLES at any samsung 3d tv?
I was trying the program 3d subtitler without any success.
A LOT OF THANKS FOR YOUR TIME AND YOUR ANSWERS
fits79 is offline
Reply 3D Tech Talk
