3d glasses for DLP Mitsubishi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-19-2012, 09:15 PM - Thread Starter
landonsdad's Avatar
Quoted: 275 Post(s)
I want to add more glasses for my 4 yr old Mits 3d DLP tv with Mits kit.
What is the best out there?
What is a good pair for the price for extras?
LG OLED65E6P Marantz 7011 ML Motion 50XT Center ML Motion 4's rear
landonsdad is offline
post #2 of 4 Old 06-27-2012, 08:50 AM
bdyer's Avatar
Tried the XPAND103's but they were just way too dark. Switched over to the Monster Vision Max 3D and couldnt be happier. Picture is bright as can be and can barely tell you have glasses on. Very comfortable!!
I have a mitsubishi 92840 and the transmitter just plug right in to the emitter on the back, update the firmware, and your all set!
The Monster's can can be had for 59.95 from monster plus coupon code "friendsandfamily25offx2012" will make it even cheaper. Can also be picked up from Monster's eBay store for 59.95.
bdyer is offline
post #3 of 4 Old 06-27-2012, 03:22 PM
kcirenox3d's Avatar
try the xpand x102 dlp link glasses or the x104 youniversal glasses if you have an ir emitter for your tv.
kcirenox3d is offline
post #4 of 4 Old 07-25-2012, 08:05 PM
Augerhandle's Avatar
Quoted: 761 Post(s)
Liked: 659
The X102s are DLP-Link, and don't run off the IR signal that the OPs original glasses use.
There are several companies with compatible glasses.
The XpanD X104s (Youniversal) are some of the best you can get, and you can take them to other people's houses, as they're universal.
For cheap (under $40) some people like these http://www.ultimate3dheaven.com/dlp3dwiglfis.html and they work with your existing setup.
At around $60, these glasses match what you have http://www.amazon.com/Samsung-SSG-2100AB-Battery-Glasses-Black/dp/B0039T7LJC (they are sold as samsung, but match exactly)
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
Reply 3D Tech Talk
