PS3 for 3D playback.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-27-2012, 08:54 PM - Thread Starter
LivestrongTL's Avatar
I have a Sharp LC60LE847U 3D television. I am trying to use my PS3 to play a 3D movie but it won't work. I have the most recent updates on the PS3 so that's not the issue. I have no idea why it won't work ...... HELP!!
LivestrongTL is offline
post #2 of 14 Old 06-28-2012, 10:08 AM
Billbofet's Avatar
Quoted: 53 Post(s)
You may need to go to "Display Settings" on the PS3 and have it re-detect your display. The PS3 will then recognize you have a 3D display, ask for the screen size, and you should be set. Unfortunately the PS3 won't recognize a 3D display without re-doing this first.
Hope that helps.
Billbofet is offline
post #3 of 14 Old 06-29-2012, 04:45 PM - Thread Starter
I did that but it never recognized the 3D TV or give me the option to put in what the size of the screen was. I have everything connected through my Onkyo 706 receiver....I wonder if that's the issue??
post #4 of 14 Old 06-30-2012, 04:57 PM - Thread Starter
TTT
post #5 of 14 Old 06-30-2012, 06:47 PM
man4mopar's Avatar
Per this http://www.onkyousa.com/model.cfm?m=TX-SR706&class=Receiver&p=i your reciever is the issue as it is only HDMI 1.3, would need to be HDMI 1.4 to pass the 3D spec.
There are various methods to make it work. All require sending HDMI from PS3 to the 3D display then sending audio in various methods to the receiver. Via Optical from the PS3 and under settings have the PS3 send audio out optical and video HDMI. Or can run the sound from tv via optical/digital coax to the receiver. All of which lose the HD sound of HD DTS or HD Dolby and will revert to DTS or Dolby which is still very good.
Or can purchase a 3D BD player with dual HDMI outs which will send HD sound to receiver via HDMI and video to display. a few panasonic 3D BD players offer this or use to.
man4mopar is offline
post #6 of 14 Old 06-30-2012, 06:54 PM - Thread Starter
Thanks very much for the reply. I was thinking it had something to do with my receiver but wasn't sure what was causing the issue. Is there an optical input on the PS3? I'll have to look at everything once I'm back home again.
post #7 of 14 Old 07-01-2012, 07:29 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Your receiver may still pass 3D. Connect your PS3 directly to your display and go through the setup process for 3D on the PS3. Then connect it back up to your receiver along with a toslink cable out of the PS3 over to your receiver so you will have sound. Setup the receiver so that you can use toslink input for the PS3 HDMI input.
Ronomy is offline
post #8 of 14 Old 07-01-2012, 03:33 PM - Thread Starter
What is toslink? I've never heard of that before.
post #9 of 14 Old 07-01-2012, 04:08 PM
Augerhandle's Avatar
Quoted: 753 Post(s)
Liked: 651
Toslink is short for "Toshiba Link". It's the optical connection between your PS3 and AVR.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #10 of 14 Old 07-01-2012, 04:48 PM - Thread Starter
Alright thanks smile.gif I was looking it up on the Future Shop website to see if they carried a digital optical cable, which they do. So, I will pick it up in a few days and play around with it all then and see what I can do. It was pretty cheap, $10 I believe. So, once I connect this cable from my AVR to my PS3 I should be all set for the 3D experience!! smile.gif
http://www.futureshop.ca/en-CA/product/startech-startech-10-ft-toslink-optical-digital-audio-cable-m-m-thintos10-thintos10/10192537.aspx?path=f764608a02d6e50ec75f1ba56f619ed3en02
hahaha, didn't even notice that it had Toslink in the description until now! smile.gif
post #11 of 14 Old 07-01-2012, 09:38 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Ck
Sorry about that! However toslink is only for audio while watching 3D movies. Make sure you connect your PS3 directly to your TV to allow for it to be setup correctly for 3D use. You can do this long before you get that toslink cable. Then after you have the TV working in 3D connect the PS3 again to your AVR to see if it will even pass 3D. It might...but it might not too!
Ron
Ronomy is offline
post #12 of 14 Old 07-01-2012, 09:41 PM - Thread Starter
Ck
Ron
Thanks again Ron, it'll be another week or so before I get home to give this a shot. When I do, I"m sure I'll be posting back to make sure I"m doing everything correctly! smile.gif
post #13 of 14 Old 07-13-2012, 04:54 AM - Thread Starter
I did what you recommended Ronomy, and it worked like a charm. Now, I just have to purchase another HDMI cable so I don't have to keep switching cables each time I want to watch 3D movies!! I really appreciate the help smile.gif
post #14 of 14 Old 07-16-2012, 07:07 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Great news but I read the info here just like you last year! LOL
Happy I could help though...enjoy!
Ron
Ronomy is offline
Reply 3D Tech Talk
