FIOS 3D TV Sound Drops - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-03-2012, 02:49 PM - Thread Starter
sethmoskowitz's Avatar
Hello --
I am not sure if this is the right thread for my question, but it sees like it could fit in multiple places.
I just got this TV: http://www.amazon.com/Samsung-UN55ES8000-55-Inch-1080p-Silver/dp/B00752NJMC/ref=sr_1_2?ie=UTF8&qid=1341351987&sr=8-2&keywords=samsung+3d+tv
I have a Denon 2112CI surround system.
I currently subscribe to FIOS.
When I watch a 3D move, it seems that the sound sporadically drops. There doesn't seem to be a rhyme or reason. It will be going fine and just drop down low and then "catch up" in volume to where it should be. I just replaced all my cables with monoprice HD cables.
Any suggestions would be helpful.
Seth
sethmoskowitz is offline
post #2 of 2 Old 07-04-2012, 10:50 AM
walford's Avatar
If you bypass the Denon and use the TV's sound does the problem still occur?
walford is offline
Reply 3D Tech Talk
