Is my cheap cable really HDMI 1.4 if I can watch 3D Bluray with Power DVD ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-06-2012, 10:40 AM - Thread Starter
tabari's Avatar
Hi,
I'm starting this thread to ask for your comments about whether my HDMI cable is 1.4
I've Nvidia GT430 installed in my HTPC and I'm able to watch 3D Bluray ISO with Power DVD (ripped from the Bluray I own as you can guess) without problems when I set the resolution to 1920x1080@24hz.
Does this prove that my HDMI cable is 1.4 compatible ? Should I seek further proof ? (it is a 10m cable which costs 13$).
* I know actually there is no HDMI 1.4, but you know what I mean.
tabari is offline
post #2 of 14 Old 07-06-2012, 11:03 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
The 1.4 spec includes networking capability. Other than that, it is the same as 1.3 and either will pass 3D. Using the new terminology, all that is required for 3D is a "High Speed" HDMI cable.
So, no, it does NOT prove that you have a 1.4 cable. You would have to try using it to pass network traffic to "prove" that it is 1.4.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 14 Old 07-06-2012, 11:12 AM - Thread Starter
tabari's Avatar
Thanks for your reply,
Pls correct me if I'm wrong, but 1.3 does not support "frame packing" like 1.4 does which is necessary for playing 3D Bluray. So, I think networking capability is not the only difference between 1.3 and 1.4 and supporting frame packing "may" be a kind of proof for 1.4.
* By the way, I only expect my HDMI cable to allow me play 3D Bluray ISOs perfectly without any quality loss.
tabari is offline
post #4 of 14 Old 07-06-2012, 12:45 PM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
This is what I know....I use HDMI cables labeled as both "high speed" (NOT high speed + networking (AKA 1.4)) and older 1.3 cables and have no issues running 3D Blu Ray.
Tom Logan
post #5 of 14 Old 07-06-2012, 02:22 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I have a 7 year old HDMI 1.1 cable and it passes frame packing just fine as well as 36 bit color. If you are not using the networking capabilities try before you buy a new cable. Actually it might be a 1.0 cable. Been so long I don't remember. Cable is an early HDMI revision from Blue jeans cable.
Ronomy is offline
post #6 of 14 Old 07-06-2012, 02:25 PM
Colm's Avatar
Liked: 94
Originally Posted by tabari View Post
Hi,
No, it is not. There are only standard HDMI cables and high speed HDMI cables, with or without ethernet. The only difference between standard and high speed is the bit rate they will support. If they support the required bit rate, they will support any HDMI 1.4 feature. The only changes in pin out since day 1 of HDMI are the optional changes require to support etherent.
Colm is offline
post #7 of 14 Old 07-06-2012, 02:33 PM
Colm's Avatar
Liked: 94
...all that is required for 3D is a "High Speed" HDMI cable.
Wrong, all that is required is that the cable support the required bit rate. 1080p24 3D has a lower bit rate than 1080p60 2D, and plenty of folks do both just fine over a standard HDMI cable.
Wrong again. There are no 1.4 cables, just standard and high speed, with or without ethernet.
Colm is offline
post #8 of 14 Old 07-06-2012, 02:37 PM
walford's Avatar
High speed HDMI cables are reccomended for HDMI 1.4a Packed buffer 3D content from a 3D BR player or PS3. Standard HDMI cables can be used for all other HDMI 1.4a formats. It is no longer legal for cables to be manufactured with any HDMI release level information.
walford is offline
post #9 of 14 Old 07-06-2012, 05:54 PM
Colm's Avatar
Liked: 94
Originally Posted by walford View Post
High speed HDMI cables are reccomended for...
...anything up to about 25'. They don't cost significantly more than standard HDMI cables, and may save you an upgrade in the future. But if your current cables don't give you sparkles or worse when viewing 3D, there is absolutely no reason to change.
Colm is offline
post #10 of 14 Old 07-06-2012, 05:57 PM
Colm's Avatar
Liked: 94
It is no longer legal for cables...
...or anything else...
... to be manufactured with any HDMI release level information.
Colm is offline
post #11 of 14 Old 07-06-2012, 06:43 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Actually when I bought this one 43 foot cable back in 2005 all it said is that it would handle the HDMI standard at that time. But since then it has passed 36 bit color at 1080p just fine. smile.gif
Although I don't use today at that bandwidth but it will pass it without any artifacts.
Ronomy is offline
post #12 of 14 Old 07-06-2012, 11:43 PM - Thread Starter
tabari's Avatar
Thanks for all inputs.
Now I'm really confused about what 1.4 means for cables, for GPUs, for HDMI switches etc.
Yesterday I tried playing 3D bluray with Power DVD connecting my old HDMI cable directly to the GPU (Nvidia GT430) and it played well.
When I connected it through my 2x4 HDMI 1.3 switch, Nvidia control panel did not show anymore the 2 resolutions under HD 3D header on the top of available resolutions (1080p24 and 720p60). Therefore, I could not play 3D Bluray with Power DVD when the HDMI switch was in the middle.
So, there seem to be a difference between 1080p60 2D and 1080p24 3D, at least for the HDMI switch which has a huge 1.3 label on it. If it is all about the bitrate, why doesn't it support 1080p24 3D confused.gif
tabari is offline
post #13 of 14 Old 07-07-2012, 10:12 AM
Colm's Avatar
Liked: 94
HDMI 1.4 doesn't mean anything for cables or anything else. HDMI logo guidelines prohibit the use of a version number with any HDMI product as of January of this year, and much earlier for cables. The reason for this prohibition is that it confuses people like you.
As previously stated, for HDMI cables, it all comes down to the bit rate they will handle.
For active devices, such as your "switch", it comes down to bit rate (until very recently no HDMI electronics could handle full high speed bandwidth) and features supported. When a source (your HTPC) and a sink (whatever you are using to display the signal) connect, the sink sends its capabilities to source, and the source selects the resolution based on that information. If there is repeater (switch) in between, it has to pass on the information to the source. It may also modify it based on its own capabilities. There is really no difference between the electronics required to pass a 3D signal and a 2D signal. A repeater only processes bits and doesn't care about the content. And there are "1.3" switches that handle 3D just fine. So, the only way a switch is going to cause this problem is either simply not passing on all the sink information to the source, or it is resetting the bits that show the source is capable of 3D. In the case of a simple switch, the solution would be to get a switch that is specified as 3D capable.
However, what you have is not a simple switch, but a matrix switch. It is a combination of a switch and a splitter. Splitters are a different beast.. Because the source can only output one resolution, and two or more sinks with different capabilities may be connected, the spltter part of the matrix will set the resolution passed on to the source to the common capabilities of the sinks. IOW if there is a 3D sink and a 2D sink attached to the matrix, the source sees 2D. I suspect this is what you are experiencing.
Colm is offline
post #14 of 14 Old 07-08-2012, 02:07 AM - Thread Starter
tabari's Avatar
@Colm
Thank you for further explanations. They helped me to understand my issue better and I will post my feedbacks later.
tabari is offline
Reply 3D Tech Talk
