optoma 3dxl and acer x1220h - AVS Forum | Home Theater Discussions And Reviews
Old 07-09-2012, 06:05 PM - Thread Starter
crazeebiker's Avatar
just recieved my 3dxl. have a sony 3d blu ray player an ps3 running to it via hdmi 1.4... when trying to link the glasses they start to limk up for a few seconds and then they loose what little sync they started to get......... Can anyone help me with getting a permanent sync with the optoma dlp link glasses..............
Id appreciate any help......
crazeebiker is offline
Old 07-09-2012, 08:41 PM
lewis3845's Avatar
It could be the Optoma's have weak batteries, external lights messing with the sync or your projector isn't set bright enough to keep the link just some ideas as I own the 3d-xl and the Optoma hd66 projector with Optoma and Xpand glasses and have never had this problem. Are you sure your in 3d mode and DLP-link is turned on in the settings for the glasses to sync?
lewis3845 is offline
Old 07-10-2012, 10:00 AM - Thread Starter
Update
Put brand new batteries in glasses. Room is a totally dark theatre room no windows or stray lights. Tried turning the brightness up on projector and still same thing. Glasses link up for around ten seconds and then loose sync. Please help with any more suggestions.
Old 07-10-2012, 03:12 PM
lewis3845's Avatar
is Dlp-link turned on in menu? is your projector saying the signal is 120hz in the info? How far away is your seating? it can effect the sync because it depends on how many lumens your projector is as how far it will sync. I know my Optoma's start to lose sync at about 18ft with my hd66 and my xpands I can go into another room and they will keep sync and the Optoma's will lose sync. Also a white matte screen will yield the best and farthest sync results
Old 07-10-2012, 03:15 PM - Thread Starter
Yep 3d on and 120
Old 07-10-2012, 03:24 PM
lewis3845's Avatar
ok 3d is on and the signal is 120hz now is dlp link turned on for the glasses to sync?
Old 07-10-2012, 03:26 PM
lewis3845's Avatar
If the glasses sync up for 10 seconds and you can see 3d during that time and your within range you might have a defective pair of glasses.
Old 07-10-2012, 03:46 PM - Thread Starter
That's what I was thinking.. i actually have the optima rf emitter and ref glasses on order.... I have a huge room and like the idea of not loosing sync when looking away from screen
lewis3845 likes this.
Old 07-10-2012, 04:14 PM
lewis3845's Avatar
The Optoma RF glasses are nice especially if you have a big room and your seating is far from the screen however it just depends on the setup with my glasses I can turn my head sideways look around and they always keep sync, but I only have a small 15 x 15 room.
Acer X1220h 2700 Lumens Dlp 3d Projector
