Understanding 3D! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-05-2012, 03:53 PM - Thread Starter
DDDude25's Avatar
Hello my dear 3Ders! Here is one confused newbie on the 3d realm! I need help.
I bought a TV LG 47LW5700. Passive 3D. I understand that 3D formats can be side by side, top/bottom, checker board and frame sequencial. I see those selections when I manually switch from 2d to 3d.
What I don't understand is, when I am playing a PS3 3D game for example, it automatically switches to 3D, what format is it using? Is it one of the above or is it something totally different? Same when I play blueray 3d? Which one does it use?
I ask because I am trying to get my PC to work with my TV! I got cyberlink powerdvd 12 and the cyberlink advisor and it passes all except the TV. It fails the TV 3D. IT doesnt' detect or something. So when I launch powerdvd 12 ultra, I think I have to manually set the display and source types and I am not sure what to select for my LG tv.
in the power DVD, there are options:
3D Ready HDTV - (Checkerboard)
Micro-polarizer LCD 3d (LCD Interleaved)
120Mhz time sequential 3d LCD
HDMI 1.4 Enabled 3d tv. (1080P, 24hz)
HDMI 1.4 Enabled 3d tv. (720pP, 60hz)
HDMI 1.4 Enabled 3d tv. (720pP, 50hz)
Now, I know I am not HDMI 1.4. I am using 1.3 HDMI cables, and it works fine on my PS3. I have no idea and coudln't find anywhere in the manual what the LG 47LW5700 is? Is it micro-polarized? Or 120Mhz time sequential 3d LCD?? If it supports both, which one is superior? Which one matches the blue-ray 3d like Lorax 3d Blueray?
NOTe that I tried the 120 time sequencial and cyberlink said content or device doesn't support!
Thanks a lot for any explantion or help. If only the TV is detected as 3d, problems would be solved...
I have ATI Radeon HD 4670 BTW, which cyberlink advisor says passes 3d. I am assuming HDMI 1,.4 is not a requirement as my PS3 plays 3d without any problem using 1.3!
---- cyberlink Advisor output ----
Check Item 3D Ready? Info
CPU : AMD Athlon(tm) 7750 Dual-Core Processor Yes
__dwItemID=1001__ : szLibCPUName = AMD Athlon(tm) 7750 Dual-Core Processor 2.70GHz
__dwItemID=1002__ : dwLibClockRate = 2699
__dwItemID=1003__ : dwLibFamily = 15, dwLibModel=2, dwLibStepping=3
__dwItemID=1004__ : dwLibNumPhysicalProc = 2, dwLibNumCorePerPackage=1, dwLibNumLogicalPerCore=1
__dwItemID=1005__ : dwLibCorePerPackage = 2, dwLibTotalLogicals=2
__dwItemID=1006__ : szWMIName=AMD Athlon(tm) 7750 Dual-Core Processor
__dwItemID=1007__ : szWMIManufacturer=AuthenticAMD
__dwItemID=1008__ : dwWMIMaxClockSpeed=2700
__dwItemID=1009__ : bBatteryExist=0
__dwItemID=1010__ : szGuess=
GPU (Hardware acceleration) : ATI Radeon HD 4600 Series Yes
Hardware Dual-Video Decoding Capability for MVC : Unknown Unknown More Info
System Memory : 3072 MB Yes
Operating System : Windows 7 Service Pack 1 Yes
Graphics Card : ATI Radeon HD 4600 Series Yes
__dwItemID=1301__ : Adapter Compatibility: Advanced Micro Devices, Inc.
__dwItemID=1302__ : VideoProcessor: ATI display adapter (0x9490)
Graphics card video memory : 512 MB
Graphics Card Driver : 8.970.100.3000 Yes
__dwItemID=1501__ : 2D Driver=8.970.100.3000
__dwItemID=1502__ : COPP=Yes
__dwItemID=1503__ : RGBOverlay=No
__dwItemID=1504__ : DEVICE=N/A
__dwItemID=1601__ : Driver 0:
__dwItemID=1602__ : [F:] HL-DT-ST DVDRAM GSA-H62N
__dwItemID=1603__ : eHCMDrvType=0x00006fc7
__dwItemID=1604__ : CDRom=1 DVDRom=1 BDRom=0 HDDVDRom=0
__dwItemID=1611__ : Driver 1:
__dwItemID=1612__ : [G:] MagicISO Virtual DVD-ROM
__dwItemID=1613__ : eHCMDrvType=0x00000fc7
__dwItemID=1614__ : CDRom=1 DVDRom=1 BDRom=0 HDDVDRom=0
__dwItemID=1621__ : Driver 2:
__dwItemID=1622__ : [H:] VXDV BD-HD-DVDROM S10
__dwItemID=1623__ : eHCMDrvType=0x00054fc7
__dwItemID=1624__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
__dwItemID=1631__ : Driver 3:
__dwItemID=1632__ : [I:] VXDV BD-HD-DVDRAM S15
__dwItemID=1633__ : eHCMDrvType=0x002d6fc7
__dwItemID=1634__ : CDRom=1 DVDRom=1 BDRom=1 HDDVDRom=0
Blu-ray Disc Drive : [H:] VXDV BD-HD-DVDROM S10 Yes
Software Player : PowerDVD 12 Yes
Video Connection Type : Digital(with HDCP) Yes
3D Display : LG TV No More Info
Program version : 2.0.5302.0
System language : 0409 ENU English English
Time : Sun Aug 05 17:54:40 2012
System Name : DUCKY
EDID:
EDID BYTES:
0x 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 | 00 FF FF FF FF FF FF 00 1E 6D 01 00 01 01 01 01
10 | 01 15 01 03 80 10 09 78 0A EE 91 A3 54 4C 99 26
20 | 0F 50 54 A1 08 00 71 40 81 C0 81 00 81 80 95 00
30 | 90 40 A9 C0 B3 00 02 3A 80 18 71 38 2D 40 58 2C
40 | 45 00 A0 5A 00 00 00 1E 66 21 50 B0 51 00 1B 30
50 | 40 70 36 00 A0 5A 00 00 00 1E 00 00 00 FD 00 39
60 | 3F 1F 52 10 00 0A 20 20 20 20 20 20 00 00 00 FC
70 | 00 4C 47 20 54 56 0A 20 20 20 20 20 20 20 01 7F
80 | A7 C2 00 65 4D 00 00 00 D5 71 57 77 B0 3A 1F 03
90 | FE FF FF FF 9A 38 53 77 92 34 53 77 80 01 D6 0A
A0 | 00 00 00 00 00 00 2E 00 88 1A 7B 0D 80 1D 7B 0D
B0 | B8 2C D6 0A B8 00 BF 01 EB 03 00 00 EA 03 00 00
C0 | 00 00 00 00 00 00 2E 00 80 0F 7B 0D 01 00 00 00
D0 | 80 1A 7B 0D 60 FC D7 02 23 E0 52 77 88 1A 7B 0D
E0 | 38 01 D6 0A 01 00 00 00 80 1A 7B 0D 74 FC D7 02
F0 | 66 32 53 77 4A FB 51 77 2C 2B 53 77 FF FF FF FF
HDMI1.4 Capability:
ATI Radeon HD 4600 Series HDMI1.4 stereo: Unsupported
DDDude25 is offline
post #2 of 10 Old 08-05-2012, 04:20 PM
walford's Avatar
The one format you did not list is the 3D Org standard dual 1080p frame packed format which is used by 3D disk players and PS3 players. The current 3D TVs such as yours will automatically switch to this format when detected. It uses 1920x2205 buffers instead of 1/2 R1080p buffers which are used by many of the other HDMI 1.4a formats used by cable and satelite companies.
walford is offline
post #3 of 10 Old 08-05-2012, 04:45 PM - Thread Starter
DDDude25's Avatar
ahaa... That is exactly what I was looking for... It doesn't show this format in the list when trying to select a manual 3d mode... it looks like it's only selected as you said when detected from a player. So it looks like Cyberlink is not using this mode becaise it's not detecting a 3D tv, correct? Maybe cause on the PC it required the HDMI 1.4! while PS3 can do it on 1.3.
Am I makign sense? Anyone has powerDVD working on HDMI 1.3 with auto detection?
DDDude25 is offline
post #4 of 10 Old 08-05-2012, 04:47 PM - Thread Starter
DDDude25's Avatar
would the frame packed be the "HDMI 1.4 Enabled 3d tv. (1080P, 24hz)" that poweredvd is referring to?
DDDude25 is offline
post #5 of 10 Old 08-05-2012, 06:08 PM - Thread Starter
DDDude25's Avatar
so, I do have a high speed HDMI cable, which means it should support 3d.
My ATI card, ATI Radeon HD 4670 seems to support 1.4...
http://support.amd.com/us/kbarticles/Pages/AMDCatalystSoftwareSuiteVersion121.aspx
They said:
Code:
IMPROVEMENTS
AMD HD3D technology support enhancement
Enables support for AMD HD3D technology in conjunction with AMD CrossFireX configurations
Delivers a new Stereo 3D mode over HDMI™ 1.4a connections - 1080p at 30Hz is now enabled on supported displays
and my card is listed under support..
so that means there should be no reason why I coudln't use the 1080P 1.4. Card support, TV is 3d and HDMI is high speed! Why wouldn't it work!! Even if I manually select it from the list, it doesn't like it.
any ideas?
thanks,
DDDude25 is offline
post #6 of 10 Old 08-06-2012, 01:42 PM
Augerhandle's Avatar
Quoted: 743 Post(s)
Liked: 649
Yes. If that doesn't work, select "Micro-polarizer LCD 3d (LCD Interleaved)" and toggle through the TV settings (top and bottom, side by side) until it matches up.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #7 of 10 Old 08-06-2012, 06:40 PM
walford's Avatar
Dual 1080p frame packed buffers in the 3D standard 1920x2025/24 buffer can be tranmitted by either a 1.3 or a 1.4 HDMI transmitter chip as demonstrated by the 3D BR players and by a PS3 player.
Which release and which version of PowerDVD do you have? I ask because all releases and versionsf power DVD do not support output ot the 3D dual buffer standard format
walford is offline
post #8 of 10 Old 08-07-2012, 10:41 AM
Lee Stewart's Avatar
Liked: 51
As long as the 3D BD player has a 2X speed BD drive, which is why the PS3 can use HDMI 1.3 (it comes standard with a 2X speed BD drive) while regular 1.3 equipped BD players can't (and cannot be upgraded to 3D BD capabilities). When 3D and HDMI 1.4 were introduced to 3D BD SAL players, so was the 2X speed drive.
Lee Stewart is offline
post #9 of 10 Old 08-07-2012, 11:18 AM
walford's Avatar
I meant to say that a PC with HDMI 1.3 transmitter chip can send packed double buffer 3D format as well as a PS3 can. The 3D bluray players allready have 1.4 transmitter chips.
walford is offline
post #10 of 10 Old 08-07-2012, 11:31 AM
Liked: 51
And again, it's more than just the HDMI TX chips. Without the 2X speed drive - no 3D BD.
Reply 3D Tech Talk
