60" Sharp 3D TV and DVD player not detecting 3D display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2012, 07:36 PM - Thread Starter
RyanCortez's Avatar
New to 3D. Have a error message "your blu ray 3D player has not detected that it is connected to a 3D display" We have went through the set up and have everything set like the manuals say to. Not sure what to try.
Can anyone help?????
RyanCortez is offline
post #2 of 4 Old 08-29-2012, 11:29 AM
walford's Avatar
Do you have your TV's 3D setting set to Auto?
What BR 3D player do you have?
What BR 3D disk are you trying?
How long is your HDMI cable?
Is there any unit connected between the player and the TV?
walford is offline
post #3 of 4 Old 08-29-2012, 02:44 PM - Thread Starter
RyanCortez's Avatar
Sharp pAcKage - tv And dvd
3d blu ray Ice age
Hdmi 10' from amp to tv
3' from DVD player to amp
Using onkyo receiver
post #4 of 4 Old 08-30-2012, 04:09 AM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
The first thing to try is plug directly to tv bypassing the amp. If works your amp isn't 3D 1.4. If it still won't work it's your HDMI cable (is it high speed)
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Reply 3D Tech Talk
Sony 3d Bluray Dvd Player
