Storing your 3D glasses, how do You do it? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 2 Post By dleasman
post #1 of 10 Old 09-21-2012, 09:34 AM - Thread Starter
Slingblayde's Avatar
Quoted: 14 Post(s)
Liked: 64
Hi Gang
I am in the process of making a dedicated home theater room in my basement, I have an Optoma HD33 and 4 sets of 3D glasses with it. I was wondering how others store their glasses. I had a friend sit on a pair and break them and I definitely dont want that happening again. mad.gif
I was thinking about putting a shelf in my rack, like one of those 2U drawers from MA, and making a foam insert in it to store the glasses. Make a small template similar in shape to the profile of the glasses and cutting the foam out so the glasses slide in. Maybe running a USB cable from my HTPC in the rack directly to the drawer so I can charge them if needed. Has anybody else done something like this? If so, what kind of foam did you use? Anybody else have any other clever storage ideas for keeping their 3D glasses safe?
Cheers!
Sling.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #2 of 10 Old 09-21-2012, 02:40 PM
Edwin Vega's Avatar
hope this will elp yo also you cand built one that can fit those 4 glasses that ou have i heva 2 vs 3d and 5 pairs and tis will work for me wood will be fine but painted:D
Edwin Vega is offline
post #3 of 10 Old 09-21-2012, 06:22 PM
Edwin Vega's Avatar
post #4 of 10 Old 09-22-2012, 06:37 PM
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Mine are passive, they're just sitting here on my computer desk.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
post #5 of 10 Old 09-30-2012, 03:19 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 64
Thats a neat idea Edwin, but I think I am going to with a drawer for my rack with a foam insert in it so the glasses slip in.
post #6 of 10 Old 10-01-2012, 08:18 PM
Chris071983's Avatar
For the time being, they are stored in their pouches on a shelf, as I don't have a dedicated HT room.... Yet.
Chris071983 is offline
post #7 of 10 Old 12-12-2012, 12:31 PM
dleasman's Avatar
I had another thought for glasses storage, as I have 12 pair (2 epson that came with my 6010 projector, and 10 pair of sony ps3 glasses, which work better anyway). I had originally ordered a sunglasses display/storage case, but the glasses did not fit in the slots... So much for that idea... But then I found a better solution. I had been thinking of storage where they could lay flat, and this was where my thinking was wrong. What if they were stored on end? What other storage options would that yield? This was my solution: A stemware storage case, for wine glasses. The cases typically hold 12, the are lined, and there are many, many models to choose from.
Here is some examples:
http://www.amazon.com/Richards-Homewares-Storage-Stripe-Stemware/dp/B007Y9QDQA/ref=sr_1_12?ie=UTF8&qid=1355343921&sr=8-12&keywords=stemware+storage
http://www.amazon.com/Riedel-Wine-Glass-Travel-Case/dp/B00005NJF2/ref=sr_1_19?s=home-garden&ie=UTF8&qid=1355344118&sr=1-19&keywords=stemware+storage+case
http://www.amazon.com/Cargo-Modern-Stemware-Storage-13-Inch/dp/B000KFUHKI/ref=sr_1_12?s=home-garden&ie=UTF8&qid=1355344118&sr=1-12&keywords=stemware+storage+case
Many of the cases are around $15, and go up from there. You can even get wooden crates, of you want something more rustic.
It works perfectly, and I recommend this for anyone with 8 or more pairs of glasses.
-Dana
Slingblayde and Patriot666 like this.
dleasman is offline
post #8 of 10 Old 12-12-2012, 01:57 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
-Dana
Very cool Dana!cool.gif I think I'll order the last one you listed (the cheapest!) next time I order from Amason. Thanks!
Ed
old corps is offline
post #9 of 10 Old 12-15-2012, 01:48 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 64
Those are really neat options for storing my glasses, but I think I am going to get a 1U or 2U drawer for my rack, get some of that gray foam, cut the foam in the shape of the glasses so they can slip into the foam in a laying flat position. That way I can just pull the drawer open, pluck the glasses out of the foam, watch a movie, and place them right back in the rack drawer.
post #10 of 10 Old 01-13-2015, 10:01 PM
etalkishere's Avatar
Liked: 0
I bought 4 3-drawer storages from Walmart, ~$9 each, total ~$30.
https://drive.google.com/file/d/0B4S...ew?usp=sharing
The drawer at the bottom is used to store batteries.
I think it's great.
etalkishere is offline
Reply 3D Tech Talk
