Ideal distance to watch 3D ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-27-2012, 04:31 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
What is the best distance to watch 3D movies in when you have a 65inch screen ? It seems that if i get a little bit closer to the TV,the pop-out effects is better and it seems that things are more popping out of the screen. Whats the ideal distance ? is 3 meters fine?
dazkyl is offline
post #2 of 5 Old 09-27-2012, 05:55 PM
jcbydesign's Avatar
From what I know it's fine. CNET has a whole article on viewing distance so I'd check that out.
jcbydesign is offline
post #3 of 5 Old 09-27-2012, 06:13 PM
Airion's Avatar
Liked: 61
In fact the opposite is true. The closer you move to the screen, the distance that pop-out effects appear to come out of the screen will be reduced. The 3D effect as a whole will diminish as you get closer. On the other hand, the more the image fills your field of view, the more immersive it will be. It's a trade off, but my personal preference is to sit very close: 6 feet away from a 90" screen. I don't think there is a definitive ideal distance.
Here's a link that explains it better than I can: http://bsandrew.blogspot.jp/2012/09/sitting-too-close-to-your-3d-tv-will.html
Airion is offline
post #4 of 5 Old 09-30-2012, 09:43 AM
manel's Avatar
i do not know about safety but few meters away from the screen would make it nicer and better for the viewers
manel is offline
post #5 of 5 Old 10-01-2012, 10:43 AM
nickels55's Avatar
Liked: 36
I sit about 2 meters from my 61" set for the best results. It is really up to you but for me I like getting a little closer than normal when 3D is active.
nickels55 is offline
Reply 3D Tech Talk
