optoma hd33 and 3d glasses compatibility i.e. ssg-3100gb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-11-2012, 02:44 PM - Thread Starter
fzhnpp's Avatar
Ordered optoma hd33 3D for $1299. Before I start purchasing glasses wondering if my samsung ssg-3100gb glasses will work. What other glasses work with the hd33
fzhnpp is offline
post #2 of 2 Old 11-12-2012, 06:59 AM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
No they won,t unless you have a compatable emitter that will plug into the universal port on the projector. Any DLP link glasses will work, Only Optoma RF glasses (not blue tooth as the 3100's are) will work with the included emitter. Samsungs 2100 ir glasses will work with a external ir emitter or any of the IR universal glasses with their IR emitter.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Reply 3D Tech Talk
