Need help with Optoma hd33 hdtv + gtx 480 graphics card (computer) + 3d blueray iso images = how do you get 3d to work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-15-2012, 08:07 AM - Thread Starter
alanwest09872's Avatar
Ok I have like I said an 3d hdtv projector the optoma hd33. I have my computer hooked up to the projector with an highspeed hdmi cable. I tried to get cyberlink powerdvd 12 to work but it said it didnt play that format of disk. It said I needed ultra powerdvd 12. Which I am ok with buying I just wanna make sure it works.
So my questions.
1. Will ultra powerdvd 12 play iso 3d blueray images
2. Is there a free software that will do the same thing.
3. How do I set this up.
a. Can I keep multi screens on or do I only have the optoma hd 33 only
b. How do I know what to select (top to bottom) or (side by side)
4. If there is anything important I am missing I would love to hear it. (General Information) ( Any extra help would be much appreciated)
alanwest09872 is offline
post #2 of 3 Old 11-15-2012, 11:42 AM
DenisG's Avatar
Quoted: 65 Post(s)
Liked: 32
Are you mounting the image?
DenisG is offline
post #3 of 3 Old 11-16-2012, 02:13 PM - Thread Starter
lol ya I am mounting the image. I was actually able to get it to work. After I got it playing the rest was easy to setup.
One problem I am having now though is fast moving object are blurry. Now if things are slow It looks perfect.
Reply 3D Tech Talk
