3D device recognition LW5600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-04-2012, 07:13 AM - Thread Starter
burtonman's Avatar
I have an LG LW5600 which will not recognize my cable box as a 3D divice. When I turn on my xbox and look at the 3d menu on the tv all options are availabe for watching tv in various 3d modes and it works great for movies from hulu etc. When I try to watch 3d movies through my hd 3d cable box from Time Warner Cable the only option that is not greyed out is the 2d to 3d option which doesnt help me watch the 3d movies. I have changed cable boxes from twc even though they say it should be recogized by the tv as a 3d device but it did not help. Any ideas?
burtonman is offline
post #2 of 5 Old 12-05-2012, 07:38 PM
walford's Avatar
Are you subscribing to the TW 3D movie channel? Does TW broadcast 3D content 24 hours a day?
walford is offline
post #3 of 5 Old 12-06-2012, 03:59 PM - Thread Starter
burtonman's Avatar
you dont subscribe you just chose how you like to watch the movie you want to purchase SD or HD or 3D. And yes.
post #4 of 5 Old 12-06-2012, 06:55 PM
fritzi93's Avatar
Liked: 41
Maybe a silly question: How is your cable box connected to your TV, via HDMI or component?
I have an LG 65LW6500 that cannot be put in 3D mode when using component output from cable. I can capture the same content with my Hauppauge HD-PVR and play it from my HTPC. Then I can select the proper 3D mode.
fritzi93 is offline
post #5 of 5 Old 12-08-2012, 08:46 AM - Thread Starter
burtonman's Avatar
HDMI
Reply 3D Tech Talk
Lg Infinia 47lw5600 47 Inch Cinema 3d 1080p 120 Hz Led Lcd Hdtv
