Problem with 3D ISO BD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-04-2012, 11:29 AM - Thread Starter
lixux's Avatar
Hello everyone,
I read many threads and I have not find a solution for my problem. So this is my setup:
Processor: Intel Core i3 3225 Ivy Bridge 3.3GHz
Ram: 8 GB DDR3 CL9.0 240pin Kingston
Motherboard: Asrock H77 Pro4/MVP
SSD: -Kingston 120GB SATA3
TV: Panasonic Viera VT50
AV: YAMAHA RX-V773 7.2
Software: Arcsoft Totalmedia player (latest version)
Powerdvd (latest version)
Everything is connected with an HDMI 1.4.
So my problem is when I come to play full bluray 3d iso. When I play full bluray (not 3d) it is not a problem. Everything run smoothy without problems.
The problems is when I play full bluray 3d isos. The tv recognises that it is receiving a 3d signal so it changes from 2d to 3d. But than the screen will turn black and remain black and the computer won't respond (the ctrl+alt+delete function won't work) and so I have to restart the pc.
I can play side by side easily but a big burden when I play 3D iso. What is the problem?
The Corei3 HD4000 should play 3d iso without problems. Or do I need a dedicated gpu? Do i need the Nvidia 3dtv play? Can i install Nvidia 3dtv play and use the software on the corei3?
Please help me since I am not an expert.
Thanks a lot.
lixux is offline
post #2 of 7 Old 12-04-2012, 04:34 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
I had this exact same problem and it turned out to be my SATA controller settings. I had to change it from IDE to AHCI in the BIOS settings. You can't just change it or you hard drive won't boot. If you do a google search on AHCI vs IDE there are directions there. If it is already set to AHCI or RAID it must be something else.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 7 Old 12-12-2012, 01:14 PM - Thread Starter
lixux's Avatar
Hi thanks for your help but that's not the problem. My ivy bridge corei3 can recognise stereostopic 3d?
lixux is offline
post #4 of 7 Old 12-12-2012, 03:25 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
My problem was not video related but had to do with software and hard drive access. My problem was reading a 3D BR off a SATA BR drive with both PowerDVD and TMT5. There are many problems reading 3D iso's and just thought if your using a SATA hard drive it might be related.
rekbones is offline
post #5 of 7 Old 12-13-2012, 12:47 AM - Thread Starter
lixux's Avatar
Thanks, please can you guide me step by step howvto change the hard disk from sata. Thanks.
lixux is offline
post #6 of 7 Old 12-13-2012, 04:18 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
Its in the BIOS settings. All computers will be different. Read your manuel for the BIOS setting and do a google search on IDE vs AHCI for directions before you change it or your hard drive won,'t boot. This may not be your issue but at least take a look at what your SATA controller is set to as in IDE or AHCI.
rekbones is offline
post #7 of 7 Old 12-15-2012, 01:40 PM - Thread Starter
lixux's Avatar
Thanks mate.
lixux is offline
Reply 3D Tech Talk
