Whats the cause of this random 3D signal??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-08-2012, 09:12 AM - Thread Starter
BigDKen89's Avatar
Equipment: Onkyo TX-NR717 receiver
Pany Vierra TC-P50T25X 3D tv
Oppo BDP-93
DirecTV, XBox 360, PS3
Monoprice high-speed cables ...everything running through Panamax power conditioner
I just recently upgraded my receiver (717 replaced the 805) to be on line with the rest of my 3D compatible theatre. For a month i didnt realize any issues with the 3D because I was sound testing. When I did, i started to notice that the system was telling me I wasnt connected to a 3D television. I double checked all my cables. Then tried another input on the tv. That fixed it...temporarily. Then i ran direct from the source, OppO, to the tv like i had before getting the 717 and that worked...again, temporarily. I switched out cables and that worked too...temporarily. I can tell immediately from DirecTV by scrolling to my subscribed 3D channels and when I'm not getting the signal, they just wont appear. It almost seems like only one will work at a time. The OppO will play 3D but when I switch to the DirecTV, it wont and vice versa. I did check the settings on the OppO, TV, and 717 but didnt find anything that consistently worked.
BigDKen89 is offline
Reply 3D Tech Talk
