dual view ghosting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-10-2012, 02:33 AM - Thread Starter
zadam123's Avatar
I have a passive lg 3d tive which supports dual view. everyone says you can just switch the lenses to 2 l/l/ r/r but when i do that it does work but there is a slight ghosting of the other player on games (black ops 2) woudl real dual view galsses get rid of this or not? also i was told that the tv would work with movietheater glasses but ones i have from a 3d movie dont work, is that normal?
thanks
zadam123 is offline
post #2 of 7 Old 12-11-2012, 03:57 PM - Thread Starter
zadam123's Avatar
anyone?
zadam123 is offline
post #3 of 7 Old 12-11-2012, 10:15 PM
cakefoo's Avatar
Quoted: 183 Post(s)
Liked: 74
Yeah, dual view is going to push your TV's ability to block the opposing views. You'll see more crosstalk in dual view than in a 3D movie or game because the player 1 and player 2 images will have a lot of differences. 3D content works well to hide crosstalk because the images are practically identical except for a tiny horizontal shift.
Your movie theater glasses might have been IMAX glasses. You need to use circular polarized glasses like those found in RealD theaters.
cakefoo is offline
post #4 of 7 Old 12-12-2012, 04:25 AM
BlackShark's Avatar
Quoted: 53 Post(s)
LG's tv glasses are compatible with RealD glasses. You won't get any improvement by changing glasses. You are hitting the crosstalk limit of your TV.
Passive 3D, forever !
My Full-HD dual-projector passive polarised 3D setup. (really out of date ! I need to update it some day...)
BlackShark is offline
post #5 of 7 Old 12-15-2012, 05:53 AM - Thread Starter
zadam123's Avatar
so my question is now will the dual view glasses be diffrent than just swapping out the lenses from regular 3d glasses?
zadam123 is offline
post #6 of 7 Old 12-15-2012, 08:52 AM
cakefoo's Avatar
Quoted: 183 Post(s)
Liked: 74
they wont be any different at all in terms of performance- you just have to make sure the lenses will fit in that side of the frame.
cakefoo is offline
post #7 of 7 Old 12-17-2012, 02:29 AM - Thread Starter
zadam123's Avatar
thanks
zadam123 is offline
Reply 3D Tech Talk
