Need help on choosing a good 3D Blu Ray player than can connect Denon AVR3310 receiver and a LG 3D TV. PLease help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-25-2012, 04:19 AM - Thread Starter
ditty's Avatar
I have a Denon AVR3310CI 7.1-Channel 1.3a receiver which is not a 3d Receiver. But I do have a LG 3D TV. Can I use this Panasonic DMP-BDT-500 to connect to my receiver as well as to my TV for playing 3D movies? I know DMP-BDT-310 can do this. But can we achieve the same results with this? Also which one is better? 310 or 500? I am not seeing much of 310 anymore. Is there any specific reason?
Please help.
ditty is offline
post #2 of 7 Old 12-25-2012, 05:55 AM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
does the 500 have dual HDMI output? The 310 is a slightly older model...
RonAlam is offline
post #3 of 7 Old 12-26-2012, 10:50 AM
Stephen Hopkins's Avatar
The BDT500 does have Dual HDMI outputs. The BDT310 does as well but, as mentioned, it is discontinued and replaced with the BDT320. The Dual HDMI output feature was unfortunately dropped from the BDP320. I would go with the BDT310 on price or the BDT500 for newer streaming features and newer Netflix interface, just depending on your priorities. Another option, though a compromise on absolute picture quality, would be any of the Panasonic 3D players utilizing the SBS output feature which can pass through HDMI 1.3 AVRs with audio. I'm currently using this approach, though with a 720p 3D Projector, so the loss of resolution isn't critical for me.
Stephen Hopkins is offline
post #4 of 7 Old 12-29-2012, 04:59 PM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
PS3 with Harmony IR adapter, by far superior to all else, just the power of the processor inside the PS3 is worth it. Not a gamer at all, use it only for Netflix, Vudu, and Amazon and LOVE IT!
Get it now before the PS3 SuperSlim is released, it will be a HT disaster with the hand-gliding Atari style disc bay cover.
bobpaule is offline
post #5 of 7 Old 12-29-2012, 05:26 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
unfortunately the PS3 has cinevia, plus the firmware updates are annoying. id go for a stand alone unit.
RonAlam is offline
post #6 of 7 Old 12-30-2012, 12:17 AM - Thread Starter
ditty's Avatar
But is PS3 a 3D blu Ray player?
ditty is offline
post #7 of 7 Old 12-30-2012, 11:26 AM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
of course it is...what kind of question is that??
RonAlam is offline
Reply 3D Tech Talk
Denon Avr3310ci Receiver
