3D on LG PA70G Projector? - AVS Forum | Home Theater Discussions And Reviews
Old 12-26-2012, 02:14 PM - Thread Starter
daltrey's Avatar
Hi,
Has anyone here watched 3D on the LG PA70G projector yet? Could you please post what settings and equipment that you are using? The manual says Nvidia 3D vision is supported and I am planning on buying it and hopefully it works. I would also like to play some games on it. I have an Asus G51VX-RX05 laptop to use. Thanks
daltrey is offline
Old 04-26-2013, 08:44 AM
a k steele's Avatar
did you use dlp link glasses? if so did you get it to play games in 3d?
a k steele is offline
