Play full 1080p 3D Blu-ray rips - AVS Forum | Home Theater Discussions And Reviews
Old 12-29-2012, 05:50 PM - Thread Starter
Onerabidmonk's Avatar
Materials:
Laptop
MSI GT683
CPU - i7-2670QM
GPU - GTX 570M
RAM - 16GB DDR3
TV
Samsumg LED 3D
UN50ES6500FXZA
Media Player
Old WDTV
Files
1080p 3D ISO
Any help would be appreaciated as I am new to this area of technology. How can I play Full (not SBS 1/2 res) 1080p 3D ISO files to my 3D tv?
Can I do it with just the stuff listed? Do I need additional software? Is it even possible?
Onerabidmonk is offline
Old 12-30-2012, 07:00 AM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 196
only comercial BR software as in Power DVD, TMT5 can play 3D ISO and the newer versions are less likely to work. Ripping any copy protected media is still considered against the law
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
Old 01-05-2013, 09:22 AM
BlackShark's Avatar
Quoted: 43 Post(s)
Liked: 25
It depends on the country. In my country (France), it is legal to make a personal copy of copyrighted material as long as you own the original physical medium (and keep the original after you have done the copy) and perform the copy with :
-your own medium (you can't download someone else's rip)
-yourself (you cant ask or hire someone else to do it for you)
-with your own copying hardware/software
-It's not a right it's an exception to copyright (you can't sue if the copyrighted material is protected with anti-copy stuff)
Check your copyright law in your country to know whether it's legal or not.
The thread title and text seem to indicate two different types of files.
-3D iso (disc image containing everything on the disc bit-for-bit, except the AACS encryption)
-Rips (re-encoded to 3840x1080 full-SBS for example)
For a 3D iso, you'll need the same software you use as with a physical BluRay (PowerDVD and co), If you have successfully removed the AACS encryption, you can also use Stereoscopic player to play individual files, however it won't play menus and tends to not like DTS-HD audio tracks.
For rips, you'll need a video player capable of playing your rips and calling your graphics card's 3D functions that manage the 1080p24 frame-packing mode. You can't set framepacking manually in the windows resolution menu, the video playback software must activate it for you. (other wise you'll be stuck in half-SBS) The only one I know it can do it for sure is Stereoscopic Player (which can use both Nvidia's 3Dvision/3DTV and AMD HD3D functions).
Passive 3D, forever !
My Full-HD dual-projector passive polarised 3D setup. (really out of date ! I need to update it some day...)
BlackShark is offline
