Help my Sony 3d DVD does not work with my Epson 3020 and switcher: - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2013, 06:19 PM - Thread Starter
racprops's Avatar
Quoted: 26 Post(s)
OK Here is my problem: Two viewers and for now two sources.
That is a Big screen TV and an Epson 3020 Projector ceiling mounted as the viewers.
Only the Epson is 3D.
The sources (for now) are a Cox Cable box and a new Sony BR-Rom 3D player.
To get the signal from the Cox box and Sony DR-Rom player I am using two 25 foot 1.4 cables, I plan on hooking in my computer at the middle, at the 25 foot point but for now am just bypassing that.
OK what works:
IF I hook the HDMI directly from the Sony to the Epson, I can watch 3D movies.
IF I hook the cable box and Sony DVD to a 3 to 1 HDMI switch I can watch 3D movies from both my cable box and the Sony.
NOTE this leaves the Big screen out of the loop, it cannot see any programing. (Darn HDMI shuts off the cable’s box’s component output when it is plugged in…)
So I have tried two different 2 out puts with 4 inputs Matrix Splitter/Switches and with these everything works BUT NO 3D.
I have tried a inline amp..at every connection and no go.
When I try to watch 3D I get a message saying there is no 3D TV and or no 3D player…
I called Sony and they said buy a Receiver with 3D support to fix the problem…
HELP
There has to be another way.
I have been reading the many threads but so far did not find one that helped.
racprops is offline
post #2 of 4 Old 01-12-2013, 01:19 PM
Rolls-Royce's Avatar
Quoted: 240 Post(s)
Liked: 354
Unfortunately, having a non-3D display and a 3D display on the same switch is the problem. When the switch sees the non-3D display come up on its network, it automatically passes that EDID to all sources to keep that display from being sent content it can't handle. There are some switches that will capture and always send the more capable display's EDID, but they are $$. Short of getting one of those, all you can do is turn off the non-3D display and the switch before firing up the system to watch 3D content. Turn on the 3D display then the switch then the source.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3 of 4 Old 01-12-2013, 06:55 PM - Thread Starter
racprops's Avatar
Quoted: 26 Post(s)
well I have received the same answer twice, next time I can I will retest your suggestion.
Thanks for your help.
Rich
racprops is offline
post #4 of 4 Old 01-16-2013, 06:12 PM - Thread Starter
racprops's Avatar
Quoted: 26 Post(s)
Well that did not work either.
Rich
racprops is offline
Reply 3D Tech Talk
Sony 3d Bluray Dvd Player
