Help no 3d on epson 3020 with PC - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2013, 12:58 PM - Thread Starter
cosmickc's Avatar
I have an HTPC with a nvidia gt610 video card run HDMI out to an epson 3020. When I play back a 3d disc some of the picture is in 3d but most of it is blurry. Any ideas what i might be doing wrong?
Kelly
cosmickc is offline
Old 01-21-2013, 08:48 AM - Thread Starter
cosmickc's Avatar
I'm still having issues that I just can't seem to figure out? I downloaded a Nvidia program called 3DTV play and installed it on my PC. Everything works when I go thru the Nvidia wizard and set up the stereoscopic 3D. Even my desktop is in 3D. But when I run a 3D Blu-ray movie, Avatar, with Cyberlink all i get is ghosting. This is driving me nutz. I have the the resolution set to 1080p 1920x1080 at 24hz.
Any help would be great.. Thanks
cosmickc is offline
Old 01-21-2013, 01:32 PM - Thread Starter
cosmickc's Avatar
Looks like I ended up solving this. Not sure If I even need 3dtv play? I was using Cyberlink DVD9 to play 3d blu-rays. (It says they are supported.) But I decided to download Windvd 11 and now everything works.
SO! In case anyone stumbles upon this thread hopefully it will help you.
cosmickc is offline
Old 09-17-2013, 01:24 PM
Wyatt Barriger's Avatar
How did you get the epson 3020 to work on a 3D PC in the first place? My projector has no signal when I plug in the HDMI from my PC into one of the HDMI 3D ports on the epson 3020. The epson 3020 isn't PC 3D ready.
Please explain.
Wyatt Barriger is offline
