MonsterVision Max 3D transmitter can't find 3D signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-26-2013, 10:57 PM - Thread Starter
yhsieh91's Avatar
Hi,
I just bought a Samsung UN60ES7150 and a MonsterVision Max 3D system.
I set up the TV and connected it with my 3D bluray player properly.
I attempted to make the MonsterVision Max 3D system work but the transmitter can't find any 3D signal.
The transmitter always shows red moving pattern, moving the transmitter or IR sensor doesn't help at all.
Spent 2 hours and still can't make it work.
Manual for the MonsterVision max 3D(http://www.monstercable.com/lit/Max_3D_manual.pdf)
Does anyone have the same problem?
Or I just got a defective unit?
Really need help..
yhsieh91 is offline
Reply 3D Tech Talk
