3d Projector not showing 3d!!! (split screen) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-30-2013, 01:50 PM - Thread Starter
brady17's Avatar
Hello every one
Love the Forum
after numerous hours wasted and money (LOL) i am at a loss and i hope some one can help me
i brought recently a NEC NP201 DLP 3d Ready
i have a Phillips BDP 2980
and a HD video Converter
ok so from the blue ray player is a HDMI lead that goes into my converter and turns the digital out put to VGA,then going into my projectors is the VGA from the converter box ... the 3d option is on on the Projector, it did say out of range but i change the 3d player to 720 and the picture came back
BUUUUT now the 3d film is just coming out as a split screen!!
i have no idea
Thanks in advance and for you time looking
James
brady17 is offline
post #2 of 9 Old 01-30-2013, 05:08 PM
Rolls-Royce's Avatar
Quoted: 368 Post(s)
Liked: 537
I believe your problem is the conversion from digital HD to analog VGA. I'm pretty sure that the framepacked format doesn't work over analog. There are units such as the 3DFury that will output a 3D signal if the display can accept the resolution and scanrate it's sending. These units take the framepacked 3D signal and put out a frame-sequential signal that will work with nearly any display.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 9 Old 01-31-2013, 03:48 AM - Thread Starter
brady17's Avatar
Sounds great! We're can I pick on of these up or what's the price range? Thanks a lot smile.gif
brady17 is offline
post #4 of 9 Old 01-31-2013, 06:16 AM
tlogan6797's Avatar
Quoted: 106 Post(s)
Liked: 133
Have you tried taking the converter out of the mix and running the player directly into the projector? I can't find anything on that projector on a google search (I even looked at Projector Central and they have nothing for that model) so I can't tell what the inputs are on it, but it seems to me that you DON'T want to downconvert from HDMI to VGA for 3D.
IF you can only input VGA, try checking out the HDFury. It's pricey, but may work for you.
And, you DO have an emitter and glasses? Or is does that projector use DLP Link? Again, can't tell since I can't find anything on it.
Good luck.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #5 of 9 Old 01-31-2013, 06:57 AM
Quoted: 368 Post(s)
Liked: 537
Good luck.
+1 on everything above. I couldn't find anything on your projector either. You'll need to google for the Fury. Digital copyright laws-and the vigorous use of said laws in lawsuits by the MPAA and other organizations-have made sales of these units within the US and Canada vanish.
...Royce...
post #6 of 9 Old 01-31-2013, 07:42 AM - Thread Starter
brady17's Avatar
Hi guys yeah the projector is 3d Dlp ready but only has a VGA input and s video
Here's the spec of my projector
http://www.necdisplay.com/p/multimedia-projectors/np-v260
Sorry I put the projector down wrong
So I have this projector and a 3d blue ray player, the blue ray player is hdmi and there is not hdmi input in my projector, so is there something that converts the signal but still carries 3d? Or any thing I can do to get his to play 3d
brady17 is offline
post #7 of 9 Old 01-31-2013, 09:05 AM
nickels55's Avatar
Liked: 36
3D ready means it needs to be hooked up to a PC to show 3D or a converter. You need to add this into the mix:
http://www.amazon.com/View-Sonic-Video-Processor-VP3D1/dp/B004ULPF50/
or this:
http://www.amazon.com/Optoma-3D-XL-Converter-Video-Gaming/dp/B0047ZH3CW/
Those will convert your other sources to the format needed by your projector.
I'd call the manufacturer to make sure before buying any other equipment.
nickels55 is offline
post #8 of 9 Old 01-31-2013, 09:18 AM - Thread Starter
brady17's Avatar
Ok I have a mac book pro... That will play on the projector But will that send a 3d signal?
brady17 is offline
post #9 of 9 Old 01-31-2013, 01:26 PM
nickels55's Avatar
Liked: 36
I believe you need to find a 3D stereoscopic player for the Macintosh for that to work.
Reply 3D Tech Talk
