3D channels NOT Recognized - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-08-2013, 08:37 AM - Thread Starter
salvie's Avatar
Hi all.
I just bought a new LG 60LM6200 3D TV. I run a Directv HR-21-700 DVR and I split the HDMI output with an Actiontec Wireless box to another TV in the kitchen. When I initially set up the TV and the receiver, the receiver detected a 3D compatible TV and the guide had the 3D channels offered by Directv. When I integrated the Actiontec Wireless box, the 3D channel offerings disappeared from the guide. The Actiontec box is powered and works beautifully but the loss of the 3D has me at a loss. I'm thinking there's some kind of signal loss in the Actiontec My Wireless box. I think I can power it by using a component-to-HDMI converter (http://sewelldirect.com/Component-to-HDMI-Converter.asp) Any ideas?
Thank You!
salvie is offline
post #2 of 9 Old 03-08-2013, 11:57 AM
Rolls-Royce's Avatar
Quoted: 240 Post(s)
Liked: 354
It may be acting like a normal wired splitter, and if so, adding the non-3D TV in the other room is what caused your 3D to go away. You see, most splitters look at the EDIDs for all displays attached to them, and will report only the EDID for the least-capable one to any source. This is so that the least-capable display doesn't get sent a signal it can't handle. In your case, that's a 3D signal.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3 of 9 Old 03-08-2013, 12:33 PM - Thread Starter
salvie's Avatar
I'm sorry, but what is EDID?
And do you think using the adapter would solve it?
salvie is offline
post #4 of 9 Old 03-08-2013, 12:45 PM
Quoted: 240 Post(s)
Liked: 354
EDID is data passed between a source and a display via DVI and HDMI with which each tells the other what it's capable of: resolutions and scan rates, audio formats, etc. "No" to the adapter-it hasn't got a thing to do with your problem. You can get a Gefen HDMIDetective box, use it to capture and store the 3D TV's EDID info, then attach it between the wireless receiver and TV in the kitchen. That way, the switch will see two 3D TVs and can't send a non-3D EDID to the DirectTV box.
...Royce...
post #5 of 9 Old 03-14-2013, 02:22 PM - Thread Starter
salvie's Avatar
OK...I'll get one. I'm just a little confused on where to install it - in-line. I have an HDMI cable coming from the source (Directv) to the HDMI splitter. One cable from the splitter goes to the new 3D TV and the other goes to the wireless transmitter box that transmits to the non-3D HDTV in the kitchen. Where does the Gefen box go?
salvie is offline
post #6 of 9 Old 03-14-2013, 02:56 PM
nickels55's Avatar
Liked: 36
Weird, as I have a 3DTV and I split the signal. The other signal goes into my Optoma HD20, a non-3D device. The 3D on my set still works, but it must have something to do with how the chain of devices go:
Cable -->TiVo HD-->Splitter (A, B)
Splitter A--> 3DA-1 (3D converter box) --> 3DTV
Splitter B--> Optoma HD20
I am sure that is the OP's issue, but curious why it still works on my set? My splitter is a POS from amazon that cost about $25.
Have you tried disconnecting the non-3D TV from the splitter and seeing if your 3D comes back on the 3D TV?
nickels55 is offline
post #7 of 9 Old 03-14-2013, 03:36 PM
Quoted: 240 Post(s)
Liked: 354
Install it between the splitter and the wireless transmitter, like this:
Splitter out---->Gefen IN. Gefen OUT---->wireless transmitter IN.
The Gefen comes with full instructions. Follow them step-by-step and you should be fine.
...Royce...
post #8 of 9 Old 03-14-2013, 03:45 PM
Quoted: 240 Post(s)
Liked: 354
You may have gotten lucky with your splitter. Some switches/splitters do not follow the convention of sending out the least-capable set's EDID, whether by design (to claim 3D capability) or to make as inexpensive a product as possible. I think the OP wasn't as lucky (nor was I, when I tried to connect a 3D and a non-3D display on the same switch).
...Royce...
post #9 of 9 Old 03-24-2013, 07:15 AM
PM-Performance's Avatar
Quoted: 246 Post(s)
Liked: 142
Watch that DVR. I have had all kinds of problems with the 3d channels either being grey or dissapearing, or telling me the channels are unavail.
The only %100 perm fix is to run optical cable for video. I ran it like this for awhile and it worked. Once I put it back on HDMI, the channels act weird again, but liveable.
My experience with this box is love/hate for sure.
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
Reply 3D Tech Talk
