Best HDMI cables for good 3d setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-31-2013, 10:32 AM - Thread Starter
LETH2AL's Avatar
Hi guys! I have some questions about hdmi cables for 3D setup.
I have a Panasonic 65VT50, denon avr-3313ci receiver, Xbox 360 and ps3. What is the best HDMI cables to use for best performance? Right now I have a bunch of old ones mixed and matched and are mostly 1.3 no names. Any suggestions would be great!!! Thanks in advance
LETH2AL is offline
post #2 of 7 Old 04-01-2013, 09:45 AM
PM-Performance's Avatar
Quoted: 246 Post(s)
Liked: 142
Im sure they all for the most part work equally as well.
I have some cheap rocketfish ones and they work perfect. I ran some cheap free ones too with no issues
Klipsch RF-82|RC-62|RS-52|RB-51, 2 Ultimax 18's in Marty Cabs Powered by Inuke 6000DSP|
Denon AVR-X4000|Oppo BDP-103|Epson 5020UB with Elite SableFrame 110"|
4 Aura Bass Shakers powered by Dayton PSA-250|4 Seatcraft 5131 seats
PM-Performance is offline
post #3 of 7 Old 04-01-2013, 09:58 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Take a look at Monoprice and Blue Jens they have all the information you need plus great prices, and what you need is high speed. You can find links to both on the bottom of the page.
Phil17108 is offline
post #4 of 7 Old 04-02-2013, 06:38 PM
walford's Avatar
How long does your cable need to be? If 15 feet or less a larger gauge or high speed is most likely not needed. Also if your are not having dropped frame, pixelation or artifact problems no change is needed. Cables are no longer allowed to be manufactured as HDMI release 3D player or from a PS3. I did see one report that a user had not 3D problems with a 50Foot "HDMI 1.3" cable.
walford is offline
post #5 of 7 Old 04-03-2013, 09:42 AM
alk3997's Avatar
Liked: 92
We get this quesiton (or similar ones about cables) a lot in the HDMI section of the AVSForum. Please see this thead:
http://www.avsforum.com/t/1465811/hdmi-1-2-pj-hdmi-1-4-cable-and-pq
The advice to try the cable is correct. HDMI bit errors produce obvious artifacts. If you aren't seeing those, then don't change the cable.
HDMI cables do not produce reduced sharpness, ghosting, changes in color, etc. Basically they transmit bits as uncompressed video information and, when there are no errors, don't change any of the bits.
For anyone who might be skeptical of the above paragraph, they can always use this cable instead:
http://www.avsforum.com/t/1466144/new-lirpa-labs-ultra-high-speed-hdmi-cables
alk3997 is offline
post #6 of 7 Old 04-08-2013, 09:51 PM
EaglePC's Avatar
RedMere at monoprice I thought it was all hype about these cables until I picked up some for my home theater equipment and must say these are best
RF61ii's
RC42ii
WS24's
RW-10D subwoofer
ONKYO AVR TX NR818
Oppo BDP-103
Cyber Power PFC 1500VA UPS
LG 55in 240hz LED 55LM7600 TV
EaglePC is offline
post #7 of 7 Old 05-15-2013, 05:44 PM
spanky250's Avatar
Unless you have some unusual circumstances (need to run HDMI 150 feet for example) a $700 HDMI cable won't make your picture any better than a $3.99 HDMI cable. Either the data will be transmitted through the cable or it won't (In which case you'll simply get no picture at all).
If the shielding is defective, you may see sparkles in the picture from interference, in which case you simply buy a cable that isn't defective. But high-dollar cables are nothing but pure profit for the manufacturers and the retailers.
spanky250 is offline
Reply 3D Tech Talk
