3D glasses signal blocked by cabinet enclosure - AVS Forum | Home Theater Discussions And Reviews
Old 04-08-2013, 04:24 PM - Thread Starter
BadAttitude's Avatar
My Sony Bravia 3D TV works well as long as the cabinet enclosure for the widescreen is open. As soon as the door is closed, the signal from the TV to activate the 3D glasses is blocked. Is there a repeater or transmitter that will fix this? There is only 3/8" space between the cabinet door and the face of the TV screen (lower left corner). What frequency is used? Is this IR ir RF?
Carl
BadAttitude is offline
Old 04-12-2013, 05:41 PM
WirelessGuru's Avatar
IR is line of sight. You could try using reflective tape or a small mirror to redirect the signal. This is what I use to extend the IR sensor when building frames around the TV casing and it works fairly well.
Last Watched 3D: Oz the Great and Powerful
It should be called Violet-Ray
WirelessGuru is offline
