New to 3d trying to figure out what's wrong. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-25-2013, 08:33 PM - Thread Starter
str1der's Avatar
Quoted: 28 Post(s)
I have an Epson 3010 projector, a panasonic BDT230 blu-ray, a high speed 3d rated hdmi cable, and universal G5 3d glasses, tried a few others also. Bought Hobbit 3D blu-ray. The 3d just doesn't seem right. Anything that's supposed to be close has a blurry gohst look to it. also it almost seems like at times the things that are in the back seemed to be in front of things that should be closer. I don't know what I'm doing wrong. I've tried running the hdmi through my receiver and directly connected to the projector with no change. Would appreciate any suggestions.
str1der is offline
post #2 of 3 Old 04-26-2013, 07:38 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Try turning the glasses upside down and see if that fixes it. If it does, then you need to reverse the L-R setting so that you you turn the glasses back the right way.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 3 Old 04-26-2013, 01:55 PM - Thread Starter
str1der's Avatar
Quoted: 28 Post(s)
Well not at home right now to try that but I did use the feature in the Epson 3010 menu to invert glasses. It didn't help. I assume that's what you're referring to.
str1der is offline
Reply 3D Tech Talk
