3D TV not detecting 3D signal / Color issue / Playback 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-28-2013, 10:44 PM - Thread Starter
Airbander's Avatar
Hello,
I am having an issue with my TV and not sure if the issue is the tv gone bad or software or what so i will add screenshots and then i will update this post with written descriptions
About my system:
vizio 3D hd tv “ 32” Theater 3D™ LCD HDTV with VIZIO Internet Apps ” http://store.vizio.com/e3d320vx.html
VIZIO 32” Class LCD Smart TV with Theater 3D®
(31.55” Diag.)
MODEL NUMBER: E3D320VX Model Features:
• Theater 3D™ - Crystal clear, flicker-free 3D
• VIZIO Internet Apps® with built-in WiFi
• Includes 2 pairs of VIZIO 3D glasses
• 1080p Full HD resolution
• 200,000 to 1 Dynamic Contrast Ratio
• SRS StudioSound HD™ audio
• USB multimedia – photos and music
• Three HDMI® ports
Thanks in Advance
imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com imagebam.com
Airbander is offline
post #2 of 5 Old 05-28-2013, 11:06 PM - Thread Starter
Airbander's Avatar
More images from my TV
post #3 of 5 Old 05-28-2013, 11:13 PM - Thread Starter
Airbander's Avatar
Hello
I use
1- Media Browser 2.6 with WMC 64 bit
2- Shark 007 Codecs
3- Nvida software
4- AMD chipset
5- Total Media Theater 5 with MB 2.6
6- WMC Player for rest of video viewing
7- PowerDVD 13
8- WinDVD 11
9- Nvida 3D Player
I have home server that i stream everything from and it is all Digital format
TV Shows
Movies
Movies series
ect
It is all Media theater HTTPC PC and i have 2 pc
More info about my issue after this update
post #4 of 5 Old 05-28-2013, 11:40 PM - Thread Starter
Airbander's Avatar
Hello
So here is the issue :
2 days ago i turn on my pc to watch a tv show , when i try to watch a tv show i discover a screen split with color of red/blue-green
i restarted the pc and same thing
What i did to fix the issue and troubleshoot the issue:
1- Clean the pc and dusted the Graphic card
2- Image the pc with new windows 7 images with chipset driver and software for graphic cards
3- updated all rest of the driver
4- install MB2.6
5- install Total media theater
ect
Then i tested this pc
Here are the results of my finding: With Medai browser
TV SHOWS TEST
Sometimes the video will play fine and sometime the video will play with low color yellow OFF Color
Restart the pc and then video playback normal sometimes or sometimes it will play off color either green as you will see screenshots or as yellow
MOVIES HD MKV H264 , AVI , WMV , ect all 1080p
it will play back fine sometime and sometimes it will be off either sound playback in background and image is black screen no pc or sometime no sound
3D Videos Full Blu-Ray
Some video play with TMT5 as extrnal player in MB with color is off or sometime pc goes dark greens color and i have to rest the pc
sometime full blu-ray will play but no image dark black screen cant exit out
3D SBS
TV never been able to play SBS in the past and now even after manual seting the tv to 3D mode with SBS
3D Top/Botom
Same thing as SBS never been able to play it is always off
Now Test with \\Computername\Drive name\Folder name\Movie folder for 3D
Normal movie will play fine in WMV player no issue or color issue sound and color is fine
SBS will play but color get off and effect wont work as usual again never been able to play SBS MKV files but now color is off
TMT5 or WinDVD
Full Blu-ray does not work by \\ because to many files to grab one to playback
TV Show play ok
I called Vizio tech support we rest the tv to factory default did not work , i switch the pc with my 2nd pc same results
2 diffrent pc with nvidia graphic card diffrent models of graphic cards
So that it that is my issue
Thank you very much in advance
post #5 of 5 Old 06-08-2013, 04:23 PM - Thread Starter
Airbander's Avatar
Hello Guys
I fix the issue so that is a good news is that i fix the problem with my SBS and HSBS / TBS Viewing
The fix:
1- Re-wrote edid for the tv
2- Update Shark007 and removed suggested shark setting
3- Updated Nvidia Drivers and 3D Vinson
4- Enabled 3D in Nvidia 3D Vision
5- Disabled set up strereoscopic 3D
That all and now everything works 2D and 3D including all formats of 3D playback
SO this is an update on this issue
Thank you very much
Reply 3D Tech Talk
Vizio E3d320vx 32 Inch Class Theater 3d Lcd Hdtv
