How to convert 2d (.srt) subs to play in a 3d (mp4) Side-by-Side movie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-19-2013, 01:19 PM - Thread Starter
tatouska's Avatar
Hi,
I've trying to find a way to convert the 2d srt subs to play in a 3d mp4 side by side movie. It seems impossible!!! Is there anyone who could help me please?
Thank you!
tatouska is offline
post #2 of 3 Old 06-20-2013, 03:09 PM
nickels55's Avatar
Liked: 36
http://www.networkedmediatank.com/showthread.php?tid=47904
May need to also convert movie from mp4 to mkv. That thread is too long for me to read so I hope it helps.
nickels55 is offline
post #3 of 3 Old 06-22-2013, 01:54 PM
Pagali's Avatar
Quoted: 12 Post(s)
A tool that has worked for me is "3DSubtitler" (google it) I've used it to make forced subs for Life of Pi and Avatar that are serviceable at the very least. I seemed to get the best results by using the idx/sub output mode. YMMV
EDIT: Instead of muxing the .idx and .sub files into the MKV container, I just saved them in the same folder (with the same filename as the movie before the .idx and .sub) Works fine in XBMC, MPC-HC, ZoomPlayer, and MediaBrowser. I would think they would work the same for MP4, but haven't tried it.
Pagali is offline
Reply 3D Tech Talk
