Optoma BG-BC100B, 3D-RF Emitter Compatable glasses? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 55 Old 10-23-2013, 06:39 PM
hardvark's Avatar
Quoted: 20 Post(s)
I too have ordered a estar combo to use with my older Optoma glassess but while the emmitter works well the glassess wont come on at all ,could the be defective or is there something besides just pushing the button to get them on??? Couldn't get the optoma emittere to stay "flipped" sync wise,estar stays fine but I also couldn't get the estar software to load on the emmitters,vip software loaded fine back to the Optoma emitter
hardvark is offline
post #32 of 55 Old 10-23-2013, 07:12 PM
PhilipSosie's Avatar
Sorry you are having so much trouble. Taking this one piece at a time....
It sound like you have at least one working emitter, so that's not broken, let's not fix it. Correct me if you don't have at least one emitter that can hold five bars. No signal = nothing for the glasses to do = they look dead, Jim.
About the dead glasses... let them charge for at least 15 minutes and try again. You can even watch them while they are still charging.
There's a first for everything and - Murphy's Law - it happen to you - but everything returned as defective so far has been either working, obviously smashed, or just had a completely empty battery and was fine after 15 minutes of charging.
Here's another possible failure mode - in the emitter setup process your glasses have been paired to another emitter, or an emitter that has since been upgraded. An upgrade preserves the IEEE ID but gives the emitter a new Zigbee ID - it is no longer the emitter those glasses married and the glasses need to be returned to factory defaults, which makes them, uh, back on the market and eligible to work with any emitter or get married again.
To restore a pair of glasses to factory defaults, start with the glasses turned off.
 Press and hold down the button
 The LED will go on solid after 1 second; keep holding down the button
 After about 10 more seconds the LED will start pulsing indicating that the glasses are ready to pair; keep holding down the button.
 After about 20 more seconds the LED will start blinking rapidly. Release the button now. The glasses will restore the factory default settings and firmware. This can take several seconds. After the process is complete, the glasses will resume normal operation.
If you do not release the button within 20 seconds after the LED begins rapidly blinking, the glasses will power off.
It's easier than it sounds written out step-by-step. This is from page 5 of the manual here:
http://www.estaramerica.com/assets/esa-bc6000_user-s_guide.pdf
Also note that if you are mixing old glasses and a new emitter, (it sounds like you are not but you may have some older glasses) then after a factory reset the glasses are rolled back to their factory firmware, so they may need some time (almost a minute) after startup to get an over-the-air firmware upgrade from the emitter. Pro Tip: The OTA upgrade takes longer if the emitter is also sending out a 3D signal.
I hope that helps.
philip (dot) sosie (at) estaramerica.com
Twitter @PhilipSosie or @EstarAmerica
PhilipSosie is offline
post #33 of 55 Old 10-23-2013, 08:20 PM
hardvark's Avatar
Quoted: 20 Post(s)
Yes haven't tried to upgrade the estar emitter, just the Optoma and a Monster one I have. The glasses give a blue led when charging but once unhooked they won't give a light at all when the button is pushed
hardvark is offline
post #34 of 55 Old 11-04-2013, 05:06 PM
hardvark's Avatar
Quoted: 20 Post(s)
I received a replacement set of the estar glassess and they work VERY well !!:DThey were very responsive and even checked them out before shipping to make sure the second set worked well before they were sent! I am extremlly pleased with them and the service I recieved
hardvark is offline
post #35 of 55 Old 11-16-2013, 06:39 PM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
I bought the most recent version of the estar products and I can't seem to fix the terrible ghosting / crosstalk.
Anyone having this issue? And I have the latest firmware as well.
I have a Mitsubishi HC8000D.
EDIT: Well, the problem is strongly accentuated by PowerDVD13. I used Stereoscopic Player and it is definitely reduced. Still slightly noticeable though.
Cory
Audio: Ascend Acoutics, Sennheiser HD 598, Denon AVR-S710W
Video: JVC DLA-RS400, LG OLED B6, 92" Dark Energy Abyss screen, HTPC/MadVR/Darblet, Samsung UBD-K8500 UHD Player, HDFury Integral
CoryW is offline
post #36 of 55 Old 11-17-2013, 11:09 AM
Here are a few guesses at what the problem might be:
1. Delay settings in the emitter are wrong. Finding the right ones can be tricky. Post #20 in this thread covers this topic as it relates to a Mitsu TV.
2. This Mitsu projector uses different delay settings than their TVs and we have to find the new settings.
3. Complete format mismatch. If your source is vertical line interleaved and your display is decoding it as horizontal line interleaved, well, that problem would trump everything else.
4. PowerDVD --> you are using a PC --> whole new set of problems that are not possible with a BRD player. Likely example: Some Mitsu displays really like checkerboard 3D. The FireGL 7700 on Win7, for example, when attached to PowerDVD and a Mitsu TV will send 3D checkerboard but OVERSCAN it, and with OVERSCAN on you are scaled out of the checkerboard pixels lining up and completely hozed. The OVERSCAN setting is a checkbox buried deep in the AMD setup utility.
I hope that helps.
post #37 of 55 Old 11-17-2013, 10:17 PM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
Thank you so much.
I am indeed using the checkerboard 3d and I have the ATI setting perfect. Overscan set to 0%.
Format seems fine.
I see the problem on frame packed and SBS.
I used the settings here:
http://www.cine4home.de/tests/projektoren/Mitsubishi_HC7800/Brillen/HC7800%20Brillen.htm
And I've tweaked for hours but the above values seem to be the best I can get.
I'm about to send these Estars back to Amazon and try the Optoma. So frustrating.
Cory
CoryW is offline
post #38 of 55 Old 11-18-2013, 04:02 AM
Sorry you are having so much trouble. I promise that the Optoma emitter and glasses will behave the exact same way. The Optoma support for your Mitsu projector may be harder to find. Something else is wrong.
Let's try a few more things.
1. Can you tune it so that the ghosting is in only in one eye? (This means the lens in the other eye is broken -- can hard to notice depending in whether the dominant eye has the broken lens.)
2. Are you at an exact frequency and resolution specified in the manual? "29.97 Hz v 30 Hz." etc.
3. Does it work with a hardware BRD player or DirecTV box?
4. Have you tried pairing the glasses to the emitter? Is it possible you have a neighbor with an emitter and the glasses are pairing to the wrong emitter? This can look wrong in a variety of ways.
post #39 of 55 Old 11-18-2013, 09:03 PM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
1. No I cannot. And I tested another pair of glasses as I purchased extra.
2. I thought you are supposed to match the frequency of the source film? I am running at 24 Hz. I have the BC6000 glasses and their manual states:
100/120/144Hz (50/60/72Hz per eye)
Plus arbitrary frequencies from 50-240 Hz
Thoughts? Another issue is that all 3D software players that work properly (besides the ghosting) automatically change the refresh rate so I can't keep it at 60 Hz even if I need to.
3. Can't test this currently. Like I said everything looks incredible except for the crosstalk / ghosting. I also tried again dialing in the delay for the best image possible and color accuracy possible. But I'm left with terrible ghosting.
Cory
CoryW is offline
post #40 of 55 Old 11-19-2013, 09:02 AM
Rolls-Royce's Avatar
Quoted: 252 Post(s)
Liked: 386
Cory, you can't match the 24 Hz of the source. If you tried to do that, with shutter glasses triggering each eye alternately, flicker would be unbearable and the picture would be unwatchable. Instead, any display that can accept a 24 Hz signal will multiply that to a higher frequency before sending it to the imaging part of the display. It's the case even in 2D.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #41 of 55 Old 11-19-2013, 10:15 AM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
Yes of course. I forgot about that. I have my projector set to take it up to 120 Hz.
Still no solution to this ghosting issue? I don't want to return this kit and glasses but I'm all out of ideas.
Once again, the settings here produces the best possible image:
Can the cable I hacked and put together cause issues? I have everything lined up perfectly as outlined in the above link. Just wondering if that could be an issue.
Cory
CoryW is offline
post #42 of 55 Old 11-19-2013, 11:21 AM
Quoted: 252 Post(s)
Liked: 386
The cable could very well be your issue. I was reading the PJ's manual online and noted that it has a 5-pin sync port, while the Bit Cauldron emitter uses 3 pins, and your link verified that. If you have an ohmmeter, go back and check for continuity between pin pairs. Also make sure you have no bridging or shorting between pins that aren't supposed to be connected..
...Royce...
post #43 of 55 Old 11-21-2013, 07:30 AM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
Well, I've given up. I'm returning the products. Going to just spring for the stock emitter and glasses for the HC8000D. I am 100% confident that the ghosting cannot be fixed. My custom-made connector is flawless and perfectly soldered just as specified in the Cine4home tutorial. I just think it could be an HTPC issue or I am less tolerant of any ghosting effect. I did get it down to where it only shows on certain scenes, but it definitely shows quite frequently.
Thanks for all your help!
Cory
CoryW is offline
post #44 of 55 Old 11-21-2013, 08:01 AM
Quoted: 252 Post(s)
Liked: 386
Sorry to hear that. Please let us know how it goes with the Mits emitter and glasses when you get them. If you still have ghosting, then you'll have to troubleshoot your source.
...Royce...
post #45 of 55 Old 11-21-2013, 09:08 PM
CoryW's Avatar
Quoted: 141 Post(s)
Liked: 101
Oh my goodness, can't believe I never considered reducing the duty cycle. This super useful post fixed the problem!!
http://www.avsforum.com/t/1379900/owners-thread-for-mitsubishi-hc7800/300#post_23979772
I just got so hung up on duty cycle... wow. It looks perfect with no ghosting at all!
Cory
CoryW is offline
post #46 of 55 Old 11-24-2013, 09:18 AM
ahmadka's Avatar
Quoted: 23 Post(s)
Guys, I'm new to the projector world, and I just purchased an Optoma HD131Xe, which I still haven't received ..
Can someone please summarize for me regarding which emitter and glasses I need to get for the best value ?
I see the Optoma branded emitter is for $39.95, the EStar 3D Starter Kit is for $64, and a single Estar 3D eyewear is for $54 ... So which option gives the better performance here ?
Also, are these emitters compatible with the Samsung SSG-5100GB 3D Glasses ? Because there much cheaper !
ahmadka is offline
post #47 of 55 Old 11-24-2013, 10:50 AM
Quoted: 252 Post(s)
Liked: 386
The Optoma emitter is just that: an emitter ONLY. You'd still need glasses. The EStar starter kit is the emitter (same as Optoma's) and 1 pair of glasses. And the EStar eyewear is glasses-only. You still would need an emitter.
The Optoma/EStar gear is NOT compatible with the Samsung glasses. Although they are both listed as RF, the Optoma/EStar set use a wireless system known as Zigbee, while the Samsungs use Bluetooth.
...Royce...
post #48 of 55 Old 11-24-2013, 12:57 PM
ahmadka's Avatar
Quoted: 23 Post(s)
Okay, thanks for clarifying .. Between the Optoma and EStar emitters, which is better ? I ask because previously in this thread you guys were discussing things like version numbers, sync issues (having to press the power button everytime it goes out of sync), etc ... So which emitter is the best currently available ? I don't want to face that manual sync/resync issue because from what I read, it seems to be annoying ..
Also, are there any alternative cheaper glasses which can also work with the Optoma HD131Xe ?
I asked about the Samsung SSG-5100GB because I'll probably get a bunch of those to go with my JVC RS-46 ..
ahmadka is offline
post #49 of 55 Old 11-25-2013, 08:42 AM
Quoted: 252 Post(s)
Liked: 386
If I were starting out, I'd go with the EStar. For one thing, the Optomas and EStars come from the same original design company, Bit Cauldron. There's likely no real difference In their basic performance. The firmware differences essentially are details in how the newer glasses use their power button. EStar uses the button as an on/off switch, while VIP, another company that sells these glasses and emitters, uses the power button to do quick polarity changes. I haven't used the newer Optomas, so I can't speak to their detail differences.
A real plus to the EStars, IMHO, is that Philip Sosie from EStar is a member here and has been active in assisting people who have questions.
Sorry, but I have no experience with other types of 3D glasses.
...Royce...
post #50 of 55 Old 02-18-2014, 07:53 PM
nosdavid's Avatar
I just got three sets of Estar rf glasses paired with an Optoma HD131xe. For the most part they work great, my only gripe is that it has a slight yellowish tint that messes up the colors, I mostly see this during daylight scenes, I can't get white to look purely white. It always has a yellowish haze. With other 3d blurays that are mostly set at night such as Pacific Rim it looks gorgeous. Is there a fix for this? I'm using 3d blurays on a bluray player.
nosdavid is offline
post #51 of 55 Old 03-29-2015, 11:49 AM
rural scribe's Avatar
Quoted: 47 Post(s)
Here's a note for anyone looking for cheap RF glasses to go with the Optoma BG-BC100B, 3D-RF Emitter.
I recently bought two pairs of Optoma BG-ZF2100GLS Active Shutter 3D-RF Glasses for $92 total, with free shipping, from Amazon. I believe these are the glasses that originally were intended to be used with this emitter.
The last time I priced these, less than a year ago, they were about $80 for each pair. Now they are selling for $46 per pair, which is about as cheap as any of the compatible substitute brands I've seen.
I'd been shopping extensively for cheap substitute glasses, and was surprised to find the price had dropped this far this fast on the Optoma brand glasses.
rural scribe is online now
post #52 of 55 Old 06-04-2015, 05:01 AM
derek's Avatar
Optoma BG-ZF2100GLS have dropped to $37 on Amazon. Just picked up 2 pairs.
Derek
derek is offline
post #53 of 55 Old 11-14-2016, 11:44 AM
Quoted: 47 Post(s)
Down to about $30 per pair on Ebay now. The newer 2300 models are a bit more expensive, and I don't know if those glasses are backwards compatible with the BC100 emitter.
I have heard that the new BC300 emitter is not backwards compatible with the ZF2100 glasses.
I think Amazon is no longer selling the 2100 glasses.
post #54 of 55 Old 11-30-2016, 06:46 AM
Liked: 0
I'm in the same boat too. Live in Taiwan, just finally purchased two pair of Optoma ZF2100 (one with an emitter)... and now I can't find any more. Like, no more in Taiwan, period. Crazy! I want to buy 4 more pair... so I guess I just wasted 120usd down the drain. It's super frustrating that Optoma/Bit Cauldron 'updated' their product line to the ZF2300 but made the two systems incompatible. Just really ridiculous. Now I'm frantically trying to find more pairs... or a 3D Vesa cable splitter... or just buy DLP glasses... Not sure what to do here at all. I love my HD26 projector but not a big fan of the situation Optoma has made for me.
Rick Kraft is offline
post #55 of 55 Old Today, 09:54 AM
Quoted: 47 Post(s)
Just be patient keep watching Ebay and Amazon, those ZF2100 glasses keep popping up now and then. On March 1 of this year I picked up my final pair of ZF2100 glasses for $32.99, shipping included on Ebay.
This same last pair I bought from Ebay did not show up on an Ebay search. Instead, they showed up on a Google shopping search, even though they were being sold on the Ebay site.
I now have six pairs which is all I need. Some of the first 3D glasses I purchased cost nearly $70 apiece back in 2014 (3D Now glasses from Canada, the cheapest I could find at the time that are compatible with my Optoma HD25e projector and BC-100B emitter).
In 2015, that price had dropped to $46. By the end of 2016, the price had dropped to $34, a little less than half the price I paid in 2014. Right now I'd say the Optoma ZF2100 brand glasses are cheaper than other compatible brands.
So the glasses are still expensive, in fact I bought a used Sony BDP-S5100 3D Blu-Ray for less money than I've paid for any pair of these 3D RF glasses I've bought.
But you can still pick up the ZF2100 glasses for less than $40 if you just keep searching shopping and don't give in to higher prices.
Reply 3D Tech Talk
Optoma Bg Bc100b 3d Rf Emitter Only
