Can't sync Vip Theater RF glasses - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-11-2013, 02:42 PM - Thread Starter
wdaub1's Avatar
Panasonic PT –4000
Dennon X-4000
Vip 3D Theater
RF emitter with glasses Firmware v1.05.010
OPPO 103
Have been using the theater for almost 2 years now with
few issues but now the glasses will not pair with the emitter.
On issue I have has since the start is that he polarity switches
each time I use the system and I have to reverse it.
Could the be part of the issue
Bill
wdaub1 is offline
post #2 of 15 Old 09-11-2013, 03:39 PM - Thread Starter
wdaub1's Avatar
the emitter is now not recognized by the Vip utility
so I guess it is defective
wdaub1 is offline
post #3 of 15 Old 09-11-2013, 03:52 PM
nickels55's Avatar
Liked: 36
Email Jonathan @ vip - he seems like a great guy. He'll help you out.
He actually facetimed with me until I got my set-up working, so I know he goes above and beyond for his customers.
Rolls-Royce likes this.
nickels55 is offline
post #4 of 15 Old 09-11-2013, 04:28 PM - Thread Starter
wdaub1's Avatar
I have and have not received a reply as of yet
wdaub1 is offline
post #5 of 15 Old 09-11-2013, 04:29 PM
Rolls-Royce's Avatar
Quoted: 407 Post(s)
Liked: 577
Glad to see you got yours working!
nickels55 likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #6 of 15 Old 09-12-2013, 03:43 PM - Thread Starter
wdaub1's Avatar
Just got an email from Johnathan and he is sending me an new emitter
So I hope I can say problem solved
Thank you Johnathan for your quick action
wdaub1 is offline
post #7 of 15 Old 09-21-2013, 05:49 AM - Thread Starter
wdaub1's Avatar
Got the new emitter from Johnathan and all is well now
Also receive the EStar glasses and emitter and they seem
to be better than the original VIP glasses I have. They
seem to make the picture brighter with the same settings
wdaub1 is offline
post #8 of 15 Old 01-25-2014, 06:59 AM
xorxhs's Avatar
using these glasses with optoma hd131xe. Im playing bluray isos with powerdvd. Emiter goes blue,indicating a 3d content, I switch on glasses, but fail to produce the 3d. Emiter has 5 blues lights on, and one 1 red (brightness). Whats your settings? I guess glasses or emitter is defective. Can you please send me the email of Jonathan in pm? How to check firmware? thx
xorxhs is offline
post #9 of 15 Old 01-25-2014, 07:59 AM
Quoted: 407 Post(s)
Liked: 577
Do you have a regular 3D Blu-Ray player and factory 3D disc to test with? Using an HTPC with ripped content adds variables that can make it harder to troubleshoot. Are you seeing a blurred image when looking at the screen with the glasses OFF?
...Royce...
post #10 of 15 Old 01-25-2014, 08:05 AM
xorxhs's Avatar
Originally Posted by Rolls-Royce View Post
Do you have a regular 3D Blu-Ray player and factory 3D disc to test with? Using an HTPC with ripped content adds so many variables that it makes it harder to troubleshoot. Are you seeing a blurred image when looking at the screen with the glasses OFF?
I don't have a standalone bluray player. I have tested with my pc (hdmi 1.4a to optomahd131xe) content, iso untouched bluray, mkv hsbs/sbs/top-bottom. Nothing works...
xorxhs is offline
post #11 of 15 Old 01-25-2014, 08:34 AM
Quoted: 407 Post(s)
Liked: 577
I strongly suggest you obtain one somehow. The closer you get to a standard HT-type 3D configuration (3D BDP w/media, 3D-capable set top box, etc.), the easier it is to figure out what's going on. As it is, we don't know if it's your sources, your video card, your player software, the emitter, the glasses, or the PJ having the issue.
...Royce...
post #12 of 15 Old 01-25-2014, 08:53 AM
xorxhs's Avatar
either way we don't know if its a non standard HT-type 3D configuration problem. Acquiring a standalone bluray player, will not help that much. Even if problem persists, ill still have to look for another pj, glasses, emitter. Id prefer if some could provide me with their settings on their pj or their soft. player program
xorxhs is offline
post #13 of 15 Old 01-25-2014, 09:45 AM
Quoted: 407 Post(s)
Liked: 577
Sure you would. If it works with the standalone 3D BDP and factory disc (which together will output a signal in an HDMI 1.4 format that 3D-capable displays will recognize) , then the problem lies somewhere within the HTPC. If it doesn't, then you know the problem lies in the PJ/emitter/glasses part of the chain. Either way, you have helped narrow it down.
...Royce...
post #14 of 15 Old 01-25-2014, 09:47 AM
xorxhs's Avatar
Sure you would. If it works with the standalone 3D BDP and factory disc (which together will output in an HDMI 1.4 format that 3D-capable displays will recognize) , then the problem lies somewhere within the HTPC. If it doesn't, then you know the problem lies in the PJ/emitter/glasses part of the chain. Either way, you have helped narrow it down.
problem is I cant find any other player. Can someone please post any settings to their ATI vga card / PowerDvD and projector? Im sure many play 3content using their pc
xorxhs is offline
post #15 of 15 Old 01-25-2014, 02:15 PM
crash2009's Avatar
I posted a suggestion for you in the projector thread. Turn off your secondary non-3D monitor if you have one.
crash2009 is offline
Reply 3D Tech Talk
