3D IR or RF? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-22-2013, 01:12 AM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
I'm trying to choose a projector between the Panasonic PT-AE8000U and Epson PowerLite Home Cinema 5020UB. The Panny has IR 3d and the Epson had RF 3d. Does anyone have any personal experience between the IR and RF versions of 3d?
ch1sox is offline
post #2 of 4 Old 11-22-2013, 05:27 AM
Audiojan's Avatar
Quoted: 18 Post(s)
The benefit of RF is that you theoretically should never lose the link between the glasses and the PJ. IR relies on line of sight to connect. For most applications IR works just fine. Keep in mind that if you're right on the boarder for IR to work and you tend to move your head back and forth (for example turning to talk to someone next to you or behind you), you may momentarily lose the connection, but the glasses should reconnect within a few seconds.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #3 of 4 Old 11-22-2013, 05:38 AM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
Very interesting.. So It basically has to "connect" with the signal for it to work properly where as the RF just works all the time. Hmmmm, thanks!
ch1sox is offline
post #4 of 4 Old 11-22-2013, 08:05 AM
tyscof's Avatar
I would say rf all the way, You will always be connected, and dont have to worry about your glasses wigging out like dlplink or ir, Have you ever used old car remotes that are ir? the worst!
tyscof is offline
Reply 3D Tech Talk
Epson 5020ub Powerlite Home Cinema 3d Front Projector , Panasonic Ptae8000u Hd Projector
