3d projector, benq W1070, cant watch 3d bluray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-22-2013, 02:09 AM - Thread Starter
gediko's Avatar
hi friends,
i have a problem with my projector. it is a benq w1070 and cant watch bluray 3d... i have a 3d bluray player (samsung) and an attached harddisk to it. while i can watch side by side movies from my harddisk, i cant watch the blurays... when i put the disc in, projector recognizes the format (frame packing) and i get a double vision but my glasses does not get active.
please help me,
thanks
gediko is offline
post #2 of 6 Old 11-22-2013, 05:29 AM
Audiojan's Avatar
Quoted: 18 Post(s)
Do you need to pair the glasses to the PJ? For most you do… look in the manual for the W1070.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #3 of 6 Old 11-22-2013, 06:14 AM - Thread Starter
gediko's Avatar
No, the manual doesn't mention about synching the glasses. Also I can watch side by side 3d from hard disk.
I have problem just with Blu-ray Discs
gediko is offline
post #4 of 6 Old 11-22-2013, 03:51 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
Your DLP link glasses are not 144hz compatible. SBS only runs a 120hz where as the Blu Ray runs triply flash 24fps for 144hz.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #5 of 6 Old 11-23-2013, 01:50 AM - Thread Starter
gediko's Avatar
This made sense sir, I will try to find a 144hz glass and try it. And I will kill my retailer smile.gif
Thanks a lot. I will write the result
gediko is offline
post #6 of 6 Old 01-07-2014, 11:41 PM - Thread Starter
gediko's Avatar
I am sorry, I am a bit late to let you know. my problem is solved as rekbones says... I received my 144hz glasses and it is working perfectly (this time i havent tried the side by side ones but i just want to watch blurays). Thanks a lot guys and rekbones especially.
gediko is offline
Reply 3D Tech Talk
Benq W1070 3d Ready Dlp Projector 1080p Hdtv
