Can anyone recommend glasses for a Samsung? - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2014, 01:02 PM - Thread Starter
Baron Blood's Avatar
Quoted: 60 Post(s)
Hello,
Can anyone recommend some different glasses from the ones that came with the Sammy F5500?
I'm looking for rechargeable ones.
Baron Blood is offline
Old 01-09-2014, 03:02 PM
richierich93's Avatar
Get the Rechargeable 3D glasses from Samsung that cost $50. There are a pair of 3D glasses from Samsung that cost $20 but they use batteries and, from what I've heard from many others, the rechargeable ones will actually give you BETTER 3D and fit more comfortably than the $20 battery-powered Samsung glasses. I own the battery operated $20 Samsung as well as battery-operated Panasonic glasses and BELIEVE ME, the rechargeable 3D glasses DO give you less flicker and tend to have less SYNC Issues. Not to mention you will save a lot of money and inconvenience by avoiding coin battery purchases. I've read that the even more expensive Panasonic Rechargeable glasses are supposed to be more comfortable, but that's all I've heard about that.
richierich93 is offline
Old 01-09-2014, 04:39 PM - Thread Starter
Quoted: 60 Post(s)
Thanks Rich!
