Optoma HD33 - 3D Mode disabled - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-17-2014, 09:18 PM - Thread Starter
Fireworld's Avatar
All of a sudden the 3D mode is disabled and I can't watch anything 3D. Can anyone help me please?? I didn't change anything, I just pressed on the 3D mode on the remote to switch to 3D and all I see is off and the option to switch from VESA 3D to DLP-Link.everything else is greyed out. I'm lost.
Fireworld is offline
post #2 of 4 Old 02-18-2014, 04:16 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
It has to do with the signal its receiving. What are you using for a source ? At 1080p it must be 24hz or change it to 720p 60hz
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 4 Old 02-18-2014, 06:00 PM - Thread Starter
Fireworld's Avatar
I just have it hooked up to a Yamaha receiver then out to my PC. do you think it's the settings in the receiver? Thanx so much.
post #4 of 4 Old 02-19-2014, 03:12 PM
rekbones's Avatar
Quoted: 407 Post(s)
Liked: 196
No its more likely the display setting in the PC.
rekbones is offline
Reply 3D Tech Talk
Optoma Hd33 3d Ready Dlp Projector
