New 3d TV, but no built in 2D-3D video converter!! - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2014, 03:40 PM - Thread Starter
Liked: 0
I got a Sony KDL42W829BBU yesterday, the 2D picture is fantastic, but it doesn't have a 2D to 3D video converter built in. Can I buy a converter box(blu-ray player/home cinema etc)? I'd like to be able to convert 2D tv from a Sky HD box(HDMI connection) into 3D
jpop_81 is offline
Old 06-19-2014, 01:25 AM
fxrh's Avatar
Quoted: 45 Post(s)
Liked: 52
An OPPO BDP-103D player would work for you. It has 2D-to-3D conversion and also allows you to use the converter with up to two HDMI inputs. In other words, you're not restricted to using the converter with discs only. So you could connect your Sky HD box to one of the OPPO HDMI inputs and then use the converter. I do this with broadcast television. Two liabilities are 1) the OPPO is expensive (but you get what you pay for), and 2) the 2D-to-3D conversion is best at the default setting; if you push it much beyond that setting, the converted 3D looks artificial.
fxrh is offline
Old 12-05-2014, 10:52 PM
Liked: 0
3D video Converter for Mac users
Well if your 3D TV does not have inbuilt 2D to 3D converstion then you can use any 3D video converter.
henri2398 is offline
